Thread: how to repair flexible hose?
    May 2009
    Jasper, TN
    249
    This may be a simple task but I haven't disconnected it yet to take a closer look.
    There is a flexible hose (looks like some vacuum hoses, with 'ribs' on it) from the skimmer to the pump. It's leaking where the large rubber connector is clamped onto the skimmer.
    Is the end of those hoses molded or is it fixable?
    I know a pic would be desireable. If my description is too confusing I'll try and get one up today.
    24' x 52" AGP = 13.5k gallons
    Dynamo 2.0 HP pump,Sand Dollar sand filter
    Polaris 65 vacuum (good when there are a ton of leaves on bottom), Pool Rover Jr. (LOVE it, but power box dead right now), AquaCritter (an excellent suction side cleaner)
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    12,089
    Re: how to repair flexible hose?
    IF the hose has a hole or crack, you should just replace it. If it is leaking where the plumbing meets, you can try teflon tape around the male end of the connection, and try reattaching it, usually the teflon tape seals the connection better. (I'm assuming here you don't have teflon tape on the joint already.)
    Yes, pics are always helpful. We're trying to envision what you describe but I could be way off!
    May 2009
    Jasper, TN
    249
    Maybe this link will help, if not I'll get a pic of my actual hose later this evening:
    http://www.intheswim.com/Pool-Equipment ... and-Clamp/
    If you look in that pic, the black hose is similar to mine. It's leaking right where the connector connects to the hose itself, not where it's clamped to the skimmer.
    I thought I saw some info somewhere that you can shorten those hoses and that the 'ends' can be pushed back over the hose where you cut it to shorten it.
    Mar 2007
    Morris, IL
    477
    If it is where the connector connects to the hose, you need a new one.
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    Fayetteville, Arkansas
    220
    I have successfully used PVC cement to repair ribbed flex hose if the break isn't too large.
    20x40 30,000 gal IG Liner, Pentair II Sand
    May 2009
    Jasper, TN
    249
    Yes it's where the connector meets the hose.
    I'll just get a new one as I need a shorter one anyway. This one is about 3 ft too long and laying on the ground.
