Results 1 to 9 of 9
Thread: Beaded liner question.. probably a stupid one ;-) PICS ADDED
    keri1973's Avatar
    Apr 2009
    Pensacola, FL
    74
    When we bought the pool they told me the liner was a beaded liner. From what I've read, when you have a beaded liner you do not have to remove the top rails to replace it. I was in the pool today and looked up under the top rail and I couldn't see any track (not sure what you call it) that the liner snaps into. I don't see how it could be replaced without taking the top rails off??? Are some different or is my liner not beaded ??
    18ft. Arcadia Round AGP - 19" Sand Filter, 1 hp pump
    Foam cove/ Gorilla Pad/ Wedding cake steps
    Sta Rite Lil' Shark cleaner and Aquabot Pool Rover cleaner - Aqua-Luminator light and return flow w/fountain attachment
    Added Borates 5/19/09 Taylor K-1005 and Taylor FAS-DPD Chlorine Tests
    Casey's Avatar
    SW PA
    10,457
    Re: Beaded liner question.... probably a stupid one ;-)
    Do you have a pic? Can you see the liner on the outside of the pool? <i.e. does it come over the walls on the outside>
    keri1973's Avatar
    Apr 2009
    Pensacola, FL
    74
    Here is a pic from the outside of the pool and 2 from the inside... sorry kinda blurry.
    keri1973's Avatar
    Apr 2009
    Pensacola, FL
    74
    Re: Beaded liner question.. probably a stupid one ;-) PICS ADDED
    bump
    Mar 2007
    Coastalish 'down easter'
    4,160
    Hey Keri
    From the pics, it looks like you do have a beaded liner.
    You should be able to access the bead with the top-rail in place, but if you can't - just remove any offending sections and do what you have to to the liner
    Luv& Luk
    -Ted
    keri1973's Avatar
    Apr 2009
    Pensacola, FL
    74
    Thank you.
    There's a difference between a "beaded" liner and a "j-molded" liner - beaded is normally found in inground pools the bead is installed and the liner hangs from it.
    A j-molded liner is what is used for fitted liners on an above ground pool - the J portion is welded to the liner and hangs over the top of the wall - and yes - you do have to remove the top rail to work on that since it holds the J in place. Problem is many people just call teh j molded liner a beaded liner - pool stores included and end up confusing the situation.
    keri1973's Avatar
    Apr 2009
    Pensacola, FL
    74
    Thanks alot, that makes since to me now.
    Mar 2009
    NJ
    215
    Yep, I had the same confusion when buying my "beaded liner". Knowing nothing about pools, I was told "with a beaded liner, you don't need to take off the top rail to replace it..." GREAT! Put it in the shopping cart! Well, it was a couple of weeks later that I found out I need a snap bead or something to hold that liner up on the wall to make it accessible from the bottom of the rail.
    It could have worked on it's own as I purchased it, but I would not have been able to take it off without removing the top rails. I had to install the 'snap bead' or 'J-hook' top coping(?) first, then the "beaded" liner could snap into and out of this rail.
    You also had to tear off the top layer, all the way around, of this beaded liner so that it can fit into this top rail.
    18' x 54" Round AG 7500 gallon w/small prefab 2-piece fandeck
    Waterways 200sf Cartridge Filter, 1.5 hp 2-speed pump. 2" pvc piping
    Pool Pilot Total Control swg w/acid tank feeder
    Pool Rover Jr., BBB, TF 100 test kit
