Results 1 to 7 of 7
Thread: Need Help with PUMP ISSUES!
    first off, I know nothing about pools/pumps so go easy on me fellas, but I will take any advice I can get at this point. So, the descriptions I give are all that I know when it comes to knowledge of pools.
    Pool Background: One skimmer, NO main drain, one jet, and a jacuzzi magnum force pump that is located uphill from the pool, and about 50 feet away from the pool. (we just purchased this house with pool in january, and i've been told that the location of pump could present problems.)
    well, I got the pump primed without issue. back pressure was 8-10. It was doing great until I decided to hook up the kreepy krauly vaccum. Like a fool, I did not fill the hose on the vacuum up with water prior to connecting it to the skimmer. I realized what happened about 10-15 minutes later. I shut off the pump, and disconnected the vacuum from the skimmer. At this point, I re-primed the pump. After re-priming it will not achieve a back pressure, and bubbles (not water) are coming out of the jet, and there is no suction happening at the skimmer. Please Help!!!!!! Sorry about the descriptions I gave folks, but it's the best I can come up with at this point in my learning phase about pools!
    ahogue (bonehead)
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Need Help with PUMP ISSUES!
    Do you have an air release valve at the top of the filter? Try opening it after priming the pump to release any trapped air in the filter.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    If there's no back pressure it hasn't been primed yet. If you have a valve for the skimmer close it off when you fill the pump, then open it just as you turn it on. That will allow you to fill the pump all the way to the lid and will give it more water to work with when priming.
    I did try the air release valve with no success(due to I haven't been able to get the pump primed yet . as far as priming it goes, there isn't a valve for the skimmer, so i've been filling up the pump while my wife has her hand covering the skimmer (arkansas valve). This also, has not worked. Thanks for your replies, I really appreciate it. Any other hints you got would be really appreciated.
    adam
    11,969
    Can you find something like a winterizing plug to put in the hole in the skimmer?
    problem solved! The o-ring apparently was no good. I replaced it, and it has maintained it's prime, BUT there is intermittent flow coming out of the jet now. It's almost like you can hear the pump give/take, give/take. The pump is primed and the gauge is reading from 5 psi to 0, during the intermittent flow delivered via the jet.
    Any suggestions with this?
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Was it the lid o-ring you replaced? If so, take a look at the other two suction penetrations: drain plug and plumbing inlet. Both those could be leaking air with the pump on. Again, the pump isn't staying fully primed.
    Also possible that a dirty filter could be giving you this issue, so if you have the option you may want to get the pump started on recirculate / bypass to pool, and then switch to filter once it's running (turning the pump off to move the valve of course).
