Thread: Help! Everything tests perfect, but pool is still green :(
    I don't know what to do any more! All my levels are testing just right, and my water is still green. When I flock it, it is crystal clear, then I vacuum everything to waste, backwash, and filter again. The next day the water is green again. Could it have to do with the well water I am adding after vacuuming? Any ideas?
    Mar 2009
    Glendora, California
    169
    Re: Help! Everything tests perfect, but pool is still green :(
    You should post your test results and how you tested, was it pool store or test kit? If test kit what kind?
    18k Inground Plaster pool / TriStar Variable Speed Pump and Controller
    48sq ft Hayward DE filter/ Swim pure Plus 40k cell / Kreepy Krauly
    Solaxx Ph-Tek
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    yes post your test results and method of testing..."perfect" does not equal green water....some numbers will help us help you...are you able to hold your FC overnight?
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Is your well water treated in any way before it comes out of the house faucets? We inject bleach in ours, then filter that out with a carbon filter. If your water is treated, are you adding treated water or straight well water? If straight well water, have you had it tested by a water testing company?
    If you can access straight well water you might run some into a glass and let it sit in the sun for a day. If it turns green, well . . . (no pun intened).
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    How are you adding chlorine to the pool?
