Results 1 to 9 of 9
Thread: Leaving my pool for 10-12 days
    May 2009
    Hamilton, Ontario
    134
    I'm leaving on my annual salmon fishing trip with the boys on Wed and I want to be sure my sweetie does not have much to worry about. She will monitor the Cl and Ph and my neighbor can help her out if anything changes drastically. I just completed a full set of tests and results as follows;
    CC-0
    TC 5.5
    Ph-7.5-7.8
    TA-100
    Ch-80
    Cya-60-ish
    I worked the PC and plan to add 5K Baking Soda and 3K stabilizer. So i have a question. Will the addition of those two items change the PH and if so what should I be prepared to do so it can be done early tomorrow. I don't really want to be trying to balance anything on Wed with more IMPORTANT things on my mind.
    Cheers
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: Leaving my pool for 10-12 days
    If it were me I would bring your CL to 10 and then tell her to watch it as it drifts back down to 5 or so .. which should take 3 -4 days to drift down depending on sunlight and bather load.
    If you go above 10 its recommended you dont swim in the pool
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Quote Originally Posted by TizMe
    recommended by who and why? while I've seen different people choose different fc levels to swim in, no one has ever said something that concrete, especially so far away from shock level.
    Butterfly's Avatar
    South Carolina
    10,045
    Hey oletrout,
    Going to Newfoundland, huh? Take lots of pix for us
    Okay, Baking Soda , NO. You do not want your TA higher.
    Stabilizer, Yes. On the stabilizer, you are going from to 60 to 80? If yes, then I get about 2.9kg too.
    (I thought you had already added this )
    Have a great trip
    You're done SLAMing when:
    Butterfly's Avatar
    South Carolina
    10,045
    Tiz, OP has a SWG
    Generally, most folks say it is okay to swim if FC levels are above the minimum and below shock levels for your CYA.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Reebok, I thought I have read in the past not to swim in FC counts over 10ppm. Maybe I misread the postings and I dont remember who said it ...
    Les
    Helpful Links:
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    If one's CYA were zero, I wouldn't swim at FC of 10.
    May 2009
    Hamilton, Ontario
    134
    Quote Originally Posted by Butterfly
    Hey oletrout,
    Jeez I'm glad you are on the ball Joyce. I said i worked the PC to get those #'s. Well, I did. Except I stupidly reversed the Now and Goal regarding the TA level
    I had a few weeks ago. We've had LOTS of rain and I have had to dump lots of excess. Dilution?? Not possible it's human error in testing. Maybe I'll sneak down and have another go at testing the CYA.
    Cheers
    Butterfly's Avatar
    South Carolina
    10,045
    Hey Gerry,
    It takes a little extra time for me when I have to do the gallons-to-metric switch-a-roo-nee on Jason's Pool Calculator
    Yea, if you have been dumping water it lowered your CYA and it is most likely NOT human error haha
    Thinking.....
