Thread: Stain from toy battery
    My DGS was playing with one of those infernal "swim" toys that require a battery. He opened it up and his younger brother took the battery and threw it in to the pool. By the time I discovered what had happened and found the battery (at the bottom of the deep end) the battery had created a stain on the bottom of the pool, similar in appearance to a rust stain. The pool is some sort of concrete pool (fairly new here, we are in SWFl - old pool was vinyl - I am not sure of the differences in types of concrete if any).
    Any suggestions as to what if anything I can do to remove or lessen this stain?
    Pool is ~25,100 gal, and I use BBB method to balance the water. I have also added salt (~2,100) and borates (43). I'm not sure if you would need my other readings, but currently FC/TC is 4, pH is 7.6, CYA 45, TA 130 (looking to lower that number some & up borates to 50 - need to pick up more MA first).
    Thanks for any help!
    Re: Stain from toy battery
    Put a couple of Vitamin C tablets in a sock and rest that on the stain for 30 seconds. If the stain is only partially gone after 5 minutes, repeat the procedure.
