Results 1 to 10 of 10
Thread: Question about filter pressure.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Friday the gage on my filter was working, increasing pressure by the end of the day. First time running.
    Saturday and Sunday I started vacuming out all the rocks,concrete,sand,etc. out of the pool.
    Put new set of filters in before starting and was using skimmer sock. Had to clean the skimmer socks about 8-10 times because of all the junk in my pool. Pressure on filter never changed. I realize I have a pretty large filter, but shouldn't it have gone up some? Skimmer socks don't work that well do they?
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Question about filter pressure.
    I have pretty much the same setup as you and hardly ever see any pressure rise in my filter. However, I never close the pool either so I don't usually have much of a clean up and never had to deal with an algae bloom. My guess though is that you do have a fairly large filter and your skimmer socks are catching a lot so I think it is probably reasonable that you don't have much of a pressure rise. Still, after your major clean up, you might consider a hose off just to make sure.
    Mark
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Sweeet. I think I'm going to like this filter
    Hey Mats, I think we did alright
    Lynn
    mas985's Avatar
    Pleasanton, CA
    11,737
    The hard part is to get motivated to actually clean the filter since it can go a long time, 6+ months, before I see any rise at all in the gauge.
    Mark
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Mark, since there is a drain in the bottom, would there be any harm in cleaning them while in the filter housing???
    Lynn
    mas985's Avatar
    Pleasanton, CA
    11,737
    Unfortunately most of the gunk sticks to the filters so they need to be sprayed off. You would probably get very little out of the drain plug. It really isn't too bad, most of the time it takes me less than 45 min to clean all four.
    Mark
    Pretty much same setup...pretty easy job to clean but you definitely need to take em out.
    A trick showed to me by my builder was when reassembling tank, use a rubber mallet intermittently to knock the retaining ring tight as you tighten the screw. Works like a charm.
    Intex 15' x 36" Easy Set Pool
    Intex 2500 gal/hr pump/filter
    Sunheater 2' x 20' Solar heater
    TF - 100 Test Kit
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Quote Originally Posted by mas985
    I'm talking about spraying them off while in the tank and letting the gunk run out the drain hole. I can turn mine on the thing they sit on in the filter.
    Maybe I'll just do as y'all say and take them out.
    Lynn
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Quote Originally Posted by linusb212
    Whew, that ring made me say a lot of "sunday school" words trying to get it back on. I have to use these huge channel locks that my hand barely fits around to squeeze the clamp together to get the nut started.
    Lynn
    mas985's Avatar
    Pleasanton, CA
    11,737
    I recently read an article in the local paper about a filter blowing up in the face of the pool owner and killing him. So it is probably safe to say that putting that band on properly is pretty important. Also, an occasional inspection of the parts might be in order as well.
    Although this seems to be a pretty rare event, this organization is trying to bring some light to the problem. This page has a list of accidents that have occured over the last 25+ years.
    Mark
