Thread: Waterway 19" Sand Filter with crack
    Hi and help-
    I have a Waterway (clearwater) 19" sand filter that has a leak around the neck where the multi valve port attaches but is leaking under the clamp to the base of the filter. We noticed there is a crack there about 1.25" long, but barely noticable in width. Is there anything I can repair this with, or do I need to buy a new round container to replace?
    98xc600's Avatar
    Jul 2007
    Southern MN
    148
    Re: Waterway 19" Sand Filter with crack
    Welcome to the forum, there is a wealth of knowledge here to help you out with any and all problems.
    I had the same thing happen to mine. I tried a few different things but they all failed in a few hours. I would just replaced it. You don't want it to fail sometime when your gone and run the pump dry, then you might need a new pump too!!
    16' by 32' cornelius AG vinyl liner, 6' deep end, 14500 gal.
    Hayward 250 Lb sand filter
    Hayward 40 GPM pump
    2-2' by 20' sun grabber solar heater.
    4 gal Liquidator. BBB
    thanks...it has helped already
