Thread: Pump--Strange Scraping Sound?
    Every now and then our pump will make a strange scraping sound, it lasts for a few minutes and then it stops. It's pretty loud and repetitive, but it usually stops on it's own or I can turn the pump off and start it up and no sound. I would say it's doing it a couple of times a day. Is something getting ready to break?
    __________________________________________
    18x36 Vinyl inground, sand filter, SWG Autopilot 60, 1 1/2 hayward pump, 300k heater
    Re: Pump--Strange Scraping Sound?
    Your Pump's bearing are wearing out. Replace pump soon. It happened to me a few years back. To costly to repair. Suggest you replace it.
    Salt Pool - Jandy Auqa Pure Chlorinator
    17000 Gal.
    Gunite
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP - madms1!!
    While it's possible that that is what's going on, it's also possible that some sand or grit is getting into the impeller
    This is the biggest (IMO) problem with answering pool questions on the net - we aren't there and therefore can't see nor hear the problem, so we end up guessing as to what's really going on
    Please don't get me wrong, I think you are probably correct as to what's happening - but... there are other options as to the problem - we just need to ask a few questions and receive a few answers to 'nail' this down 8)
    L2w, see if it isn't the motor seal itself (check for water dripping under the pump)and please provide us with a little more info, if the underside of the motor/ pump housing is dry
    We CAN help you through this
    Luv& Luk
    -Ted
