Results 1 to 20 of 20
Thread: Panty Hose in place of skimmer sock
    Jun 2007
    Eastern NC
    53
    Just curious if anyone has tried putting a panty hose in the skimmer to catch the smaller stuff. Kind of like the skimmer sock that I saw at the pool store. Would it hold up?
    24k IG Vinyl D.E. Filter, SWG
    Sure that will work. Many people use knee highs, which are closer to the same size as a skimmer sock.
    Yeah, I use them. The knee highs actually come in a little gum machine bubble at walmart for 33 cents a pair. Not worth wearing since they are odd colors, but they work for my pool skimmer!
    Hurricane Rita did not kill me, but she killed my pool!
    Intex 36'X18'x52" "elliptical pool"/ Hayward 220 filter/1HP pump 14,364 gal, or so
    KurtV's Avatar
    Mar 2007
    SE Louisiana
    270
    I use the knee highs when I use anything in the skimmer. They're cheaper than the skimmer socks and you can get them at the grocery store instead of a pool store but they don't last as long and I don't think the mesh is quite as fine as the skimmer socks.
    Fayetteville, Arkansas
    220
    Just started using knee highs as skimmer socks. They work great and are easy to clean with a garden hose. We have a couple of labradors and you know what that means. I can't imagine not using them now! I bought several of the 'gumball' packaged ones at Wal-Mart and I'm still using the first pair after pouring BBB over them.
    Getcha' some.
    20x40 30,000 gal IG Liner, Pentair II Sand
    INHO there are just as good as the pool socks. I used skimmer socks 5 for $7 last year, now I am using 2 knee hight for 33 cents. They don't last as long, about 5 days vs 7 days, but they catch almost everything that the socks did. White is the best color to use because they do not have any dye.
    They beat the socks out of the socks for value!
    36,000 buster crabbe inground vinyl aquagenie
    1 hp hayward sand filter
    Houston, Texas, USA
    148
    Skimmer socks: 5 for $8
    Panty hose: $1.75
    Asking your wife for one of her panty hose: Priceless
    Of course I told her it was for the pool. She just shook her head and said "I don't even want to know".
    Poor Man's Pool
    Doughboy 18 ft round above ground
    7600 gal with center drain
    Pentair sand filter, 1 HP pump
    50 ppm borates
    "I know just enough to be dangerous"
    Pool Calc Ver 1.41 (Excel)
    220
    Quote Originally Posted by Poseidon
    Panty hose: $1.75
    Uhh .. just asking ... where do you stuff the rest of the panty hose so that the skimmer actually works??
    I buy the white knee high style at Wal-Mart for like 39 cents.
    Hope everyone's summer is going well ...
    Houston, Texas, USA
    148
    Quote Originally Posted by Rangerman
    Panty hose: $1.75
    I cut a piece off. I had a heck of a time getting it on the skimmer basket. After that hassle, I tried a skimmer sock. Much easier. I'll try the knee highs once I go through the socks.
    Poor Man's Pool
    50 ppm borates
    Jun 2007
    Mesa, AZ
    34
    How do you "install" the knee high/skimmer sock? Do you just pull it over the whole basket and do you have to be sure to only pull it up the sides of the basket and not let it go over the top opening of the basket? I'm thinking of trying it with my new pool because there are a lot of trees in the neighbor's yards that shed very small buds and blossoms that my skimmer doesn't seem to catch. We just had ours finished earlier this week. Thanks.
    IG, Shotcrete, PebbleTech, 30 1/2 x 13, 13000 approx. gals, 1 1/2 HP Jandy pump, 2 1/2 plumbing, cartridge filter, SWG, ozone system, PV3 in-floor pop-up cleaning, Mesa, AZ
    Carrollton, TX
    126
    engteach43, you need to put the sock/pantyhose/kneehighs inside the basket and secure it around the top edge. If you put it over the outside, it could become clogged with debris and get sucked off the basket and possibly through the pipe
    Nice pool! With the AZ heat I bet it will be appreciated!
    7000 gallon IG freeform w/ 6 ft. spa, 21 ft weeping wall, Hayward SP4020NS Northstar pump, Colorlogic LED’s, DE6020 filter and H400IDL2 400,000btu heater. Aqua logic 8 zone controller with Aqua Rite salt chlorine generator, Stonescapes pebble finish – Aqua Blue and flagstone coping, stamped/stained concrete deck
    Jun 2007
    Mesa, AZ
    34
    Okay. When I put the knee high on that way it is stretched real tight across the top of the skimmer basket. Do I need to find a way to get the knee high to go down more into the inside of the basket? I also dropped a river rock into the basket to help keep it from popping out of the skimmer.
    I think you're good to go. Water flowing through the knee high will draw it into the basket, partially, and probably more than enough to do the job.
    Jun 2007
    Mesa, AZ
    34
    Btw Txborn, thanks. We love the new pool and with temps as high as 117 in the last couple of days we sure are appreciating it.
    Jun 2016
    Baton Rouge, Louisiana
    1
    Re: Panty Hose in place of skimmer sock
    What if the skimmer has a handle sticking up out of the middle of the skimmer? Should I remove it, put the knee high on, then try screwing the handle back on? Does anyone have a skimmer with a handle that uses a knee high?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by Tara L. View Post
    Couldn't you just pull the knee-high on all the way to the toe over the top of the handle and then let the excess sag inside while the rest is attached to the edge of the basket?
    It would be sort of W shaped, but with the center point taller than the rest. Trust me, it'll pull down when it starts filling up with debris.
    Jun 2016
    Borrego Springs CA
    4
    Has anyone tried filling a knee-high pantyhose with a half pound 2 pound of cya and suspending it in the skimmer?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Yes, knee highs work great! Hanging in front of a return is good too.
    Jun 2016
    Borrego Springs CA
    4
    I ended up grabbing an old white cotton sock, added about pound of cya and jammed the end of the sock through one of the holes of my skimmer cover and tied a noose knot. A day later the CYA had broken down into a loose wet powder and when I squeeze it it releases it into the skimmer. It couldn't be any easier and I'll be able to reuse the sock indefinitely. So much for buying pantyhose!
  20. Back To Top    #20
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Better and much cheaper than knee highs or skimmer socks...hairnets, the kind used for food workers. Price $6.00 for 100 or $18.00 for 500. At that price you just pull them out and throw them away, no rinsing or dealing with the contents.
    Disposable Hair Net, Spun-Bonded Polypropylene, White, 100 per Bag: Science Lab Hairnets: Amazon.com: Industrial Scientific
    ProWorks DA-BC210 Bouffant Cap 21 Inch Disposable Polypropylene 500 caps per Case: Protective Beard Covers: Amazon.com: Industrial Scientific
    chiefwej
