Thread: New Member with some questions
    Just wondering what to use to lower PH with a vinyl IG with SWG. Thanx
    12K GL 16x25 IG VINYL , AUTOPILOT SWG , HAYWARD CARTRIDGE FILTER,
    1HP SUPERPUMP,HP2100TCO3T HEATPUMP
    SR SMITH TYPHOON SLIDE
    BORATES.TF100 TEST KIT
    Casey's Avatar
    SW PA
    10,461
    Re: New Member with some questions
    Muriatic Acid. Follow the dosage on the Pool Calculator in my siggy!
    Guest
    If you are having problem with the pH rising too fast your TA might be too high or your CYA too low.water-balance-tips-for-a-swg-t3663.html
    The guy at the pool store told me muratic acid wasn't safe for a vinyl lined pool.I guess maybe cause he doesnt sell it
    Jan 2009
    Cupertino, CA
    1,966
    You want to add it by pouring it slowly in front of a return jet with the pump on, so it will distribute fairly quickly. It can damage the liner if you just dump it in and it doesn't distribute right away.
    --paulr
    BBB "Intermediate Swimmer"
