Results 1 to 7 of 7
Thread: New POOL's FULL...Pumps not working yet! Now what?
    reallytiredteacher's Avatar
    May 2009
    Southern Missouri
    38
    We are fixing to finish filling our DIY IG with 22,000 gallons of water and it's Father's Day so Nothings open and we're short a couple of elbows to finish the plumbing to the pump/filter. It will be functioning Monday afternoon.
    The question is what should I do in the mean time? We filled 1/2 the water Friday eve. and now the other 1/2 is finishing now. I tested and got these numbers with the T-100 kit i ordered from TFP. We filled with the city hydrant. Should I put any chemicals in there or just leave it? Kids are going to swim in it this eve cause they've been waiting 3 weeks and there's no stopping them.
    Chlorine less than .5
    PH 7.8
    CYA 0 (of course)
    I know what to add and amounts to add from the pool calculator, but figure since I can't circulate them very much I should prob wait. Will the two fire hoses mix up a gallon or two of bleach enough when they put in the final foot or more of water? What about the CYA? Wait til the skimmer is running and hang the stabilizer in a sock? Have one of my kids drag a filled up sock around the pool with a pole? (They'd like that!!!)
    I know someone has asked this question before, but I seach quickly and couldn't find it. We still have to finish backfilling with a wheelbarrow and I don't have time to browse this site.
    WATER IN THE POOL....IT's a GREAT Day at our house!!!
    22K gal IG Vinyl 18'x36' rectangle (Hydra Pool Kit, Homebuilt DIY Spring09) 8' deep end
    Aqua Genie (No Main Drain, No Separate Returns), Hayward 1.5hp Pump, 24" sand filter & 2" Pipes, Jandy WaterColors LED Light, Flyte DeckII/FibreDive Board
    :sun: Added for 2010~ SWG CompuPool CPSC36, "The Pool Cleaner 2x" suction cleaner, PICS of our DIY build, and our DIY Lime Green SLIDE refinishing project!
    Casey's Avatar
    SW PA
    10,427
    Re: New POOL's FULL...Pumps not working yet! Now what?
    I'd put CYA in a sock, tie it up and let the kids squish it around while playing in the pool. Or you could get in and do it! 8)
    Arizona
    924
    Do not wait to add the chlorine. Mix it up by brushing your walls and floor.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    30,413
    In a 22k pool, one small jug of clorox mixed in each evening will probably work to hold off algae. Don't dump it straight in but rather mix it around.
    I'm inclined to wait on the CYA. I'm not sure how acidic it is and I don't think it should be in touch with the liner for too long. Certainly, put it in as soon as your pump is running.
    Casey's Avatar
    SW PA
    10,427
    I wasn't really telling her to throw it in the pool and leave it there. I know when I do mine, I squish it while in the sock and never had a problem with it burning my hands or anything like that. I figured if the kids wanted to get in and play, giv'em the sock of CYA and let them manipulate it until it disolve into the water while they splash around.
    I, personally, don't see an issue with it.
    May 2009
    Southern Missouri
    38
    THanks guys for all the quick info. I put a jug of Wal-Mart bleach in very slowly as the two firehoses put in the last thousand gallons or so. I waited on the CYA since the answers were mixed. Pump and filter will be running by tomorrow afternoon.
    The pool is full and kids are swimming now. Pics will come soon and will include from ground break to completion. Right now I have Turkey Grit (used for backfill...scoop, rake, & shovel- OH MY!!!) from head to toe and I'm taking a shower so I can get in the pool for the first time. YipEE!!!
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Let's see those pics!
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
