Thread: fix low ph or high ta first?
    Willamette Valley, Oregon
    3
    Hi there. I just converted from baqua to chlorine starting last monday thanks to this site. It only took three days to get the water clearer than its ever been. My chlorine level is holding overnite for past three days and CC is below .5 so I'm moving on to balancing the water.
    My taylor 2006 test this morning shows
    FC 5
    CC .5
    PH 7.2
    TA 130
    I'm confused about which to treat first the ph or the ta. from what I've read, it says to lower the the ph to 7.2 with acid to get the ta down and then aerate to raise ph back up, but my ph is already at 7.2. So do I raise my ph with borax and then lower is with acid? Help!!! Oh...I also added 4 lbs cya 2 days ago as suggested by your calculator (which works awsome on my iphone by the way)
    Happy Father's Day by the way
    16X32X48" Doughboy AG with 6' deep end, 1.5 HP/Sandfilter
    Bob_Funk's Avatar
    May 2009
    Seattle-It really rains all the time
    113
    Re: fix low ph or high ta first?
    No, you want to raise your pH thru aeration, & then when it reaches 7.8 lower it down to 7.2 with acid, which will also lower your TA, repeat until your TA is where you want it
    Read this article from the pool school
    pool-school/lowering%20total%20alkalinity
    I consider myself very lucky I found this site before the pool store found me-pool owner since Nov 2008- Stunningly clear 17,000 gal fiberglass pool, thanks to this site, installed in 1982-24" 3.1sq. ft sta-rite sand filter, 1 hp - 2 speed wisperflo pump-WFDS-4
    30,403
    Fireman,
    I would leave both your TA and pH alone. They're in the ballpark and I see no reason to adjust them.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    yeah that whole lowering ta thing is mainly if you're having a frequent ph rise (frequent acid additions) and want to slow it down. you don't have to adjust ta just to reach a certain number, it's whatever works for your pool.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Have you changed your filter media and added CYA?
