Thread: How long for CYA to dissolve?
    I just put about 3 lbs of CYA in the sock and dropped it in the skimmer. How long till the big ball of CYA dissolves? How long till I should do a test for CYA in my water?
    16 X 32 Vinyl. Hayward aqua rite salt system, T -15 cell. Hayward H250 gas heater, Hayward 1HP superpump.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: How long for CYA to dissolve?
    Quote Originally Posted by jonmar
    That will depend on your water flow. Maybe one day, maybe two? Don't test for your CYA until about a week after it has dissolved.
    You're done SLAMing when:
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    mine usually dissolves in a day ....
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    Jul 2007
    Alamo, CA
    187
    I recently put a few pounds of granular stabilizer in a fine mesh bag and left it in my skimmer. It took almost two weeks to completely dissolve, in spite of a seemingly vigorous flow that had it tumbling around in there for more than six hours a day.
    blubluenoiseise
    My pool: 14,750 gallons in-ground plaster
    FAFCO Solar panels (seven 4' x 12') with a Goldline automatic controller
    1/2 HP WhisperFlo filter pump, Kreepy Krauly cleaner, Cartridge Filter
    Aquarite SWG, Satisfied user of the TF-100 Test Kit
    Guest
    general rule of thumb is put it in and test it a week later.
    Don't even worry about it until the week has passed.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I recently added some. I put the sock in the skimmer first, but since I have my pump on low and only 50% of the water goes thru the skimmer, it wasn't dissolving very much after 24 hours. So I moved it to the return, and it dissolved within the next 24, the water flow by the return was much better.
    Ditto, wait a week to test, but after 24 hours after it's done dissolving, assume it's in there. So if you added enough to target 50, assume your CYA level is 50 and adjust your FC levels according to the CYA chart.
