Results 1 to 7 of 7
Thread: Are the TF100 test kit chemicals dangerous???
    I recently bought a TF100 Test kits and I was wondering where do you guys perform your test???
    I've performed most of my tests inside my garage. The garage is next to the pool. But I've also done some test inside my house. Also after I complete my test I always discard the water in a corner of my backyard or if I'm in the house in my sink.
    Are the chemicals in the test kit dangerous that I shouldn't dump the water down my kitchen sink when testing inside my house???
    Thanks.
    Above Ground, 8,000 gallons, Hayward DE bump filter, Vinyl
    30,403
    Re: Are the TF100 test kit chemicals dangerous???
    The chemistry you use is of such low volume and so diluted, you could probably drink it. (please don't do that )
    Nevertheless, I test in the kitchen and pour all of the leftover solutions into a 16 oz cup. I then fill the cup with water and pitch it into the yard.
    Each person's comfort level is a bit different. I know many folks who put it right back in the pool. maybe 2-3 fl oz of solution in the average 20k pool makes for pretty good dilution, IMO, but others will prefer not to do that, regardles of how dilute it is.
    Guest
    I test in the bathroom and pour it down the drain. I do not recommend pouring it back in the pool.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Our goes down the drain in the kitchen with the water running. I tried testing at the pool a few times but while I was there the light timer went off so I wound up going to the kitchen anyway to test !
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    Great,
    Thanks for replies. I just wanted to make my actions were not causing any danger to my family. Specially for when I test indoors and dump to the sink.
    Guest
    Quote Originally Posted by gugarci
    Great,
    The chemicals in the test kit are no more dangerous than many things you already have around the house. DPD powder is about as dangerous as hair dye (DPD is used as a dye base in hair dye) One of the CH readents is a very dilute sodium hydroxide solution (LYE) but very dilute. If you have any drain cleaner in the house it is far more dangerous.
    The TA titrant is very dilute sulfuric acid. If you have any liquid toilet bowl cleaner in the house it's a stronger acid!
    The reagents do deserve respect but they are nothing to be afraid of!
    Some water testing chemicals can be damaging to cultured marble sinks. I used to test water a LOT for fish tanks, and something I dripped on the bathroom sink stained it badly. Can't recall what the solution was testing for, the drops themselves were clear and I failed to rinse the sink afterwards. Later these brown spots appeared, got worse with time. I eventually tried to sandpaper them off but the stain went very deep into the cultured marble material. Those tests were for Nitrates, phophates, chlorine and other things for planted fishtanks.
    Kinda funny that my last hobby was about growing things in water, now I try to not grow things in water.
