Results 1 to 7 of 7
Thread: Do you keep your pump and filter on or off???
    Quick question since this is another weekend where the pool is not going to be used due to the weather. I think I'm living in the rain forest. We opened up the pool on Memorial Day weekend and due to cold temps and now rain almost every day, for the last 2 weeks, we still have not used our pool. Hoping next weekend will be the one.
    Anyway my question is the following. When you guys used your pool do you guys keep your pump and filter on or off??? I used to keep on but someone told me I should turn it off for safety reasons, electricity, water, and kids splashing not a good combination.
    So if we ever get to used our pool this summer should I keep it on or off while the pool is being used???
    Thanks.
    Above Ground, 8,000 gallons, Hayward DE bump filter, Vinyl
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    360
    Re: Do you keep your pump and filter on or off???
    Unless your pump is mounted on the top of the pool, it shouldn't be a problem. It's all designed for outdoor, rain exposed conditions. Of course if the rain continues enough to flood your yard (we're in hurricane alley...that's happened to us) and the pump gets submerged, then pull the plug and open the breaker. I sometimes turn the return eyeball up parallel to the surface and float around on the lazy river!
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    No my pump and filter is behind the pool and it sits on a small wooden platform very close to the ground.
    Cassiopeia's Avatar
    Jun 2008
    Tampa Bay FL
    46
    Quote Originally Posted by gugarci
    Thanks.
    Sometimes mine is on, sometimes off. Doesn't really matter to me. Although I do enjoy when it is on because the force of the water swirling pushes me around the pool in my tube.
    15' ROUND, 52" AG
    Newbie at pool ownership!
    Laenini's Avatar
    Aug 2008
    Brooklyn Center, MN
    90
    Quote Originally Posted by Snark
    I am so going to try this!!!
    Leanne
    Pool: 24' round by 48" deep AGP
    Waterway 1HP-2 speed pump, H100 Heater, sand filter, skimmer, using BBB (love it!)
    Hot tub: 2008 CalSpas, 8x8, 8 seats, 60+ jets, ozonator
    3 step bromine sanitation
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    It all depends if your pool/pump is properly grounded or not. You should seek the advice of an electrical expert.
    I like the filter running when we are in, because the kids stir up all the crud and I don't have to vacume.
    geoshecks's Avatar
    May 2009
    Perry Hall Maryland North of Baltimore
    77
    ANY electrical outlet in a potentially wet area should be on a GFCI circuit. A GFCI senses a fault or short situation and throws the breaker. Most outside circuits should be GFI. The breaker in the box may be GFI or a GFCI outlet may be used upstream from the pool outlet. Codes vary, so if you are unsure about the wiring, hire a qualified electrician for peace of mind. If your pump is properly grounded, and you have a GFCI circuit, there is no problem running the filter while swimming. Don't EVER run an extension cord to any outlet which you are not sure is GFCI. Don't EVER defeat the third prong on an extension cord.
    Geoshecks
    Perry Hall, Maryland
    27' round above ground, 17100 gal, vinyl, Hayward1.5hp, 200lb.sand, EX baqua-goo user.
