Results 1 to 10 of 10
Thread: Add Bleach to Skimmer or in Front of Return Jet?
    I could have sworn when I first started reading all the info on TFP that I read that bleach should be poured directly into the skimmer. Now this morning, I'm seeing a few places where you recommend adding in front of a return jet, including "How to Chlorinate Your Pool" in PS. (Why newbies should read PS first!)
    We've probably put 10-12 174.oz jugs in our pool since last Saturday - lots at a time as we were shocking - poured directly into the skimmer. Should I be worried that any damage was done to the filter, pump etc?
    13.5K gal IG vinyl, Hayward 1 HP pump, 20"-ish sand filter
    Casey's Avatar
    SW PA
    10,438
    Re: Add Bleach to Skimmer or in Front of Return Jet?
    I pour in front of the return but there are a few who do pour it into the skimmer.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    I pour ours into the pool, not necessarily in front of the return but fairly close to it. We have an open area on one side of the deck where the pump is and I usually take water samples from there as well. It saves my aging butt from going up the steps to the pool deck !
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    Casey's Avatar
    SW PA
    10,438
    TizMe,
    Please know that if you don't use it you lose it!
    *back to regularly scheduled thread*
    Arizona
    924
    Lolly, you are gonna be okay. Just don't do it from now on. I'm thinking that bleach is probably the least harmful to have added through the skimmer.
    Personally, I add most of my chems on the opposite side of the pool from the skimmer, and in the deeper part of the pool.
    There are occasionally products that instruct you to pour them in the skimmer, but generally you should not get in the habit of it.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Quote Originally Posted by TizMe
    I'm with you TizMe
    But back to the question at hand. I pour miine in front of the return, and boy have I been pouring. (New pool,sunny,and 95-100, whew)
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Later today I will post a pic of what the trip to the pool looks like for me and you will understand why go to the "open" area and skip some steps lol
    Les
    Helpful Links:
    30,419
    The "in the skimmer or in front of the return" discussion is as interminable as "which filter is best?"
    Common sense would indicate that either method is acceptable if you use some judgement about the rate at which you introduce the chemistry.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    In this picture you will see why I take the short cut for water samples at the pool.
    Picture taken from deck at back of house. I go around to the left of the deck because the filter is on this side of the pool as well.
    Les
    Helpful Links:
    Butterfly's Avatar
    South Carolina
    10,045
    Lolly, we usually pour slowly in front of the return in the deep end; however, sometimes we walk and pour around the perimeter of the pool.
    Tiz, we certainally do understand the 'short cut'!
    You gotta lotta steps!
    You're done SLAMing when:
