Thread: Diving Board
    Kannapolis, NC
    89
    Diving Board
    I have lost my diving board bolts, I am curious can I get the stuff from home depot, or are these bolts special.
    _________________
    My Pool:
    Foxx Pool Grecian style 19' X 39'
    27k, with a 300# sand filter
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Diving Board
    Quote Originally Posted by Bowlin
    As far as I can tell, they are nothing special. Mine look like regular steel bolts.
    Mark
    Casey's Avatar
    SW PA
    10,427
    Re: Diving Board
    They'll probly be the funnest bolts you'll ever buy!
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: Diving Board
    I would caution you to buy RATED bolts with the markings on the heads. Unmarked bolts mean unrated bolts, and you have no idea what their strength will be. Since you have lost the bolts and presumably have no idea what strength you need, buy the kind with 5 hash marks on the heads for maximum strength. It would be particularly embarrassing and expensive liability wise for the bolts to snap mid-jump on someone and for them to be injured.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
