Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: FC loss in 24hrs
    Jun 2008
    Port Neches, Tx.
    144
    FC loss in 24hrs
    I'm just curious if anyone could give me some average numbers on their FC PPM loss over a day. Preferably some southerners, our pool hits 90 degrees during the day lately with alot of sunshine. I just got done clearing the pool from a dash of algea, I cought it quickly and got on top of it fast. Yesterday I went without the swg during the day for 12hrs to start bringing the FC down and I lost 5ppm, just wondering if this is about right.
    Noob Here!
    24' Above Ground
    Aquatrol SWG
    1 1/2 hp pump, sand filter
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: FC loss in 24hrs
    2ppm is the going rate. it can vary. are you sure you got all the algae? did you do an overnight fc loss test?
    pool-school/overnight_fc_test
    Jun 2008
    Port Neches, Tx.
    144
    Yes, thats when I stopped the shock.
    My #'s this morning.
    FC - 16.5
    CC - 0
    TA - 80
    CYA- 65 added some this morning, had a leak up till last week, might still have a smaller one.
    Salt - 3100
    Noob Here!
    24' Above Ground
    Aquatrol SWG
    30,421
    5ppm in a days time is pretty far above average, even for your Southern conditions.
    I would suggest letting the FC go back down to normal for a day or so and then do another overnite FC loss test.
    Remember, only two things consume chlorine.....sunlight and organics (usually algae).
    Jun 2008
    Port Neches, Tx.
    144
    I'll try that.
    Noob Here!
    24' Above Ground
    Aquatrol SWG
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by newnick
    FC - 16.5
    CC - 0
    TA - 80
    Salt - 3100
    Losing 5 ppm out of 16 ppm is only about 30% extinction which is about what I see at a CYA of 65 ppm. So I think what you are seeing is reasonable.
    Mark
    Jun 2008
    Port Neches, Tx.
    144
    Over Friday night I lost close to 1ppm. From 20 to 19
    Left the swg off another 12 hrs, 24 hrs total, dropped to 14.
    So I guess I'm closer to 25% than 30%, does that sound right?
    Noob Here!
    24' Above Ground
    Aquatrol SWG
    Jun 2008
    Port Neches, Tx.
    144
    A week has gone by now, been running 24/7 and trimming back the swg.
    Numbers this morning after shutting down the pump over night.
    FC 11.5 Lost .5 overnight
    CC 0
    PH 7.6
    TA 80
    CYA 80
    I've trimmed the swg back to 25 percent through the week running 24/7 easing the FC down. I'd like to go back to 12on/12off to cut back on electicity. If running at 25 percent was working 24on/0 off can I go to 50 percent and run a 12/12 schedule and be close to the same amount of chlorine production?
    Noob Here!
    24' Above Ground
    Aquatrol SWG
    Woodberg's Avatar
    Apr 2009
    Houston, TX (Candlelight Estates)
    136
    I'm in Houston and we are also averaging about 4ppm FC usage each day. I've down the nightime test and the FC is holding steady overnight. I just think its the intense heat right now. During the spring I was averaging around 2PPM FC usage each day.
    20,000 gallon gunite pool, attached spa, Pebblesheen finish, Paramount PCC-2000 infloor cleaning system, Paramount ClearO3 ozone system, Intelliflo VS main pump, Whisperflo 1HP cleaner pump, StaRite cartridge filter, StaRite heater
    Arizona
    924
    We had a couple of what I'll call intensely boggy days a couple weeks ago where we were losing 5 to 6 ppm per day.
    I guess I'd describe boggy as stale heavy feeling air.
    Since then it's been hotter and even more humid some days but loss has been only 2 to 3 ppm over 24 hours.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    I'm on the Gulf Coast and our pool water temperature is 92 F right now. My target FC is 4.0 and I have been losing a constant 1.5 - 2.0 ppm chlorine every 24 hours since March. In fact it's been amazingly constant. The water has stayed clear as clean glass. I have to add about 2 or 3 cups of acid once a month to keep the pH down and I've had to add ten pounds of baking soda to bring the TA up and that's all I've done since late February. I have not even had to backwash the filter since (I believe) the 1st of May.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    Jun 2008
    Port Neches, Tx.
    144
    Do ya'll run your pumps 24/7 ?
    Are there any trees close to your pools?
    Noob Here!
    24' Above Ground
    Aquatrol SWG
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    I run my pump 12 hours per day 7 days per week from 8 am to 8pm. And yes, I have a ton of trees around my pool, live oak, hickory, dog wood, Chinese cotton ball, maple, and a little further away lots of pine. There is also a creek that runs into a swamp just outside my back fence. The pool gets full sun from about 9 am until about 5:30 pm (if I keep the trees trimmed).
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by stev32k
    Have you considered running your pool at a lower TA level since that may reduce the rate of pH rise letting you use less acid and baking soda? What is your current TA level?
    Outside temp has been an average of 95 with a pool temp of 91.
    I have been using anywhere from 3.5-7ppm in a 24 hour period lately; it depends on how much the kids swim and how many go swimming.
    27' round AG vinyl, 54" height with 18,200 gallons of water.
    1HP pump, 150lb sand filter run 12-14 per day. Using 12.5% liquid chlorine. BBB method.
    Taylor K-2006 test kit. Lamotte strips for borate at 50ppm.
    Goals: CYA-40, TA-80, FC-4, CC-0, Borate-50, PH-7.4-7.8 with use of fountain.
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Quote Originally Posted by chem geek
    I maintain the TA between 50 & 90. My last TA test was 80 ppm. I'm pretty sure the pH rise is due to using the cheap wal-mart bleach. That brand has a large excess of sodium hydroxide. I've read (can't remember where) that it can have as much as 20% excess caustic.
    Mar 2007
    San Rafael, CA USA
    12,082
    There's no way it's 20%. It could be 2% which would be high and yes, would contribute to rising pH. Clorox Regular unscented has very low "excess lye" in it -- around 0.25% -- so should have minimal pH rise compared to the off-brand bleach you are using. Or course, it's probably more expensive.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Well, all pools are unique but I've been using Wal-mart bleach for over 2 years and my PH and TA don't budge.
    Woodberg's Avatar
    Apr 2009
    136
    How low would you suggest? I have a very similar situation to stev32k. We are experiencing extreme heat and my pool temp is hovering around 92-93 degrees. My TA is currently at 80 and my PH is rising rapidly. I'm having to add acid every 1-2 days to keep it in check. We've been out of town for a few weeks this summer and I've used Trichlor tabs while away. Other than that I use bleach. What I've noticed is that the acidity of the tabs keeps my PH pretty constant. Also, we have a raised spa which cascades water down into the pool. I think the constant aeration is not helping the situation.
    I know there's not a definitive answer on where to set the TA, but if you could give me a best guess target to aim for I'd appreciate it.
  20. Back To Top    #20
    11,969
    Try 60, if you have constant aeration. I wouldn't go lower.
