Thread: Mike18, Newbe from central Illinois
    Illinois
    5
    Hi all.
    I've been lurking around and finally registered.
    Then I lurked around some more...first thing I realized is, I needed something better than test strips, so I ordered the TF100 test kit yesterday.
    Now I'm on a quest for a pool cleaner so "back to searching"!!!!!!!!!!!!!!
    Thanks for all the info I've gathered so far.
    22,000 gallon
    Cristal-Flo™ II 250 lb. sand filter
    30 foot round above ground
    1.5 hp. 12 amp. pump
    TF100 Test Kit
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Mike18, Newbe from central Illinois
    Welcome to the forum
    Congrats on your TF100 and your sig is great
    You're done SLAMing when:
    Guest
    Welcome to our corner of the 'net! I can see you've read pool school and the forum rules! Such a refreshing change!
    If you have any question just ask. Remember, the only dumb questionis the one you don't ask!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Welcome!
    Mar 2007
    Coastalish 'down easter'
    4,160
    Hi Mike Welcome to TFP!!
    Ya done good on pre- reading and setting up a sig. It will be a sincere pleasure to respond to any questions you have that I'm qualified to answer
    Luv& Luk
    -Ted
    Illinois
    5
    Thanks for the great Welcome.
    I hope I don't make a pest of myself.
    By using the search I have found answers to questions I didn't even know I had.
    22,000 gallon
    TF100 Test Kit
