Thread: Help!!Calcium scale on bottom of vinyl liner?
    I am trying to help the neighbors open their pool. It was a swamp. It is clearing up now. I have noticed that the bottom of the pool is rough like sandpaper. I believe it is calcium scaling. The liner was put in last year but the pool was not cared for properly. How can it be removed? Thanks in advance
    20K IG Vinyl Pool, 1HP Hayward SuperII Pump, Pentair Tagelus TA 60D Sand Filter, AutoPilot SC-48 SWG, Letro Legend Cleaner
    Guest
    Re: Help!!Calcium scale on bottom of vinyl liner?
    replace the liner.
    I keep working on it for now. Scrubbing the heck out of it. It was helping a little. Then I was vacuuming the pool and the suction was very good and pulled the vacuum head down until it stuck on the bottom. I pulled on it until it broke free and low and behold there was a clear path of no scaling. Does anyone think that it will hurt the pool to try to get it to get stuck and clean it that way? Thanks
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Not sure. If you keep the PH at 7.2 for awhile if the scale is rather fresh maybe that will help release it.
