Results 1 to 7 of 7
Thread: Newbe with a few questions
    Huntsville, AL
    26
    Hi,
    I'm new to the forum and pools and have a few questions .
    I have been lurking and reading the pool school for a couple of weeks in anticipation of the new 16x24 AG pool with 16" sand filter going in next week.
    I would like to know if anyone has any dos/don't for me as I will be filling and testing sometime next week with the TF-100 test kit I have just received.
    1. How much of what chemicals should I go ahead and purchase for start up?
    2. Anything special I should do as I fill the pool for the first time?
    I'm sure I will have lots of questions for you guys once I get started, so please be patient with all the questions I will have
    YBnormal...have a pool
    15' x 30' Beachland AG Pool (12000 gal.)
    Hayward 1 HP Power-Flo LX Pump
    Hayward 18" Sand Filtration System
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    Re: Newbe with a few questions
    If you have access to your fill water now, you can test it and post it.
    People smarter then I will then be able to give you some direction.
    20'x40' / 30,000 Gal / In Ground / Vinyl
    Pentair FNS 48 DE Filter / Pentair Challenger 1.5 HP Pump
    Jandy Lite2 400k BTU Propane Heater / Dolphin Dynamic cleaning robot
    TF-100 Test Kit / BBB
    Creator of SimplePool (BBB Friendly Android App) http://www.simplepool.net
    Butterfly's Avatar
    South Carolina
    10,045
    Hi ybnormal and welcome
    Yep, as kenmar said, you should test your fill water. Don't waste reagent testing for CYA.
    Post back here with your test numbers.
    Congratulations on your TF100 Test kit!
    You're done SLAMing when:
    Huntsville, AL
    26
    Thanks for the responses, what a great place for a newbe like me. I will crack open that test kit and give it a shot.
    Will post the results of the fill water today I feel so much better knowing I have knowledgable folks to help me through this
    Huntsville, AL
    26
    Are there any certin tests I need to run on the fill water??? I'm sure there are some that are not really required like CYA....correct?
    30,421
    YB,
    No real need to do the chlorine test or Calcium test. If it's city water you may have a little chlorine but not enough to affect your pool and Calcium is not a requirement for a vinyl pool (but it's conceivable you have too much)
    That said, it's a good idea to perform all the tests for practice.......I would say the CYA is an exception since you know it will be zero there's really no value (pun intended ) in the test.
    I would suggest to do them all except the CYA and post them up for comment.
    Huntsville, AL
    26
    Will do....thank you
