Thread: Drain in the deep end
    If there is a drain in the deep end where does the water go when you drain the pool?
    20K gal.
    Hayward S-244T sand filter
    IG vinyl
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Re: Drain in the deep end
    Usually into the neighbor's yard, depending upon where you point your backwash hose.
    Seriously, the drain in the bottom of the pool is not like the drain in the bottom of a sink. It's another intake point for the filter system. That way your filter can pull from the bottom of the pool as well as from a skimmer at the top.
    So to recap, water leaves the pool from a skimmer or drain, travels through the pump and filter, and returns to the pool by way of the .... ummm... 'returns'.
    Jan 2009
    Cupertino, CA
    1,966
    If the local water table might be a problem, the main drain often has a relief valve in it, so when you're trying to pump water out, and it goes below the water table level, the relief valve starts letting groundwater in.
    --paulr
    BBB "Intermediate Swimmer"
