Results 1 to 13 of 13
Thread: Significantly different PH in deep end versus shallow end?
    Jul 2008
    Dallas, Texas
    27
    My pH readings are significantly different if I take them in the deep end versus the shallow end. In the shallow end near a jet I am getting readings of deep purple around 8 and at the deep end at around 7. I couldn't find any posts on this in any searches. Should I just assume I am in balance at around 7.5 or do I error to the readings in the deep end? This seems like a problem.
    30,000 Gallon Renovated Pool and Spa
    Flagstone Coping and Wall
    Onyx Quartz Plaster
    72 SF D.E Filter
    Polaris 280 Cleaner
    Jandy Aqualink Control Center and Palm Remote
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Significantly different PH in deep end versus shallow end?
    sounds like really poor circulation. had the pump been running 30-60 mins when you did this? are you taking the samples 12-18" below surface? (about elbow deep should be good). what are your other numbers?
    Jul 2008
    Dallas, Texas
    27
    Yes, pool has been running all day and always take the readings above the elbow deep. The deep end has worse circulation for sure as the spa waterfall really moves the water on the shallow end. I usually have the returns pointing upward to shoot across the water and push leaves toward the skimmer. Maybe I should point the returns more down towards the bottom?
    Onyx Quartz Plaster
    72 SF D.E Filter
    Polaris 280 Cleaner
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    you have a giant pool like that with no main drain in the deep end? pointing an eye down will help increase circulation down there. there is also a product called the circulator if the pros here think you have major issues with that kind of difference. maybe it would help.
    Jul 2008
    Dallas, Texas
    27
    Yes, there is a drain down there but the water is definitely more still in the deep end as it looks to me like they should have put in an extra jet or two.
    Onyx Quartz Plaster
    72 SF D.E Filter
    Polaris 280 Cleaner
    30,432
    pH in a circulating pool should be very even and stay that way easily. I suspect some type of testing error. What are you testing with?
    May 2009
    West Tennessee
    33
    Could it be possible that the aeration from the waterfall elevates his Ph on that end? Granted the entire pool should have relatively the same Ph, but with the aeration only on one end it will take some time for the water to mix and equalize right?
    29,000 Gal. 18' X36' Vinyl - IG- Hayward 1HP Superpump with Haywrd 250# Sand Filter- Circu-Pool RJ 45 SWG - GO VOLS!
    Guest
    I second this!
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Quote Originally Posted by poolpop
    wrong ends. it should be opposite if that was happening cause aeration raises ph and his ph is high in the deep end, whereas the waterfall is in the shallow.
    Jul 2008
    Dallas, Texas
    27
    Deep end is around 7
    Shallow end is around 8
    Higher in shallow end.
    Onyx Quartz Plaster
    72 SF D.E Filter
    Polaris 280 Cleaner
    Jul 2008
    Dallas, Texas
    27
    I am taking multiple tests and using the FAS-DPD kit.
    Onyx Quartz Plaster
    72 SF D.E Filter
    Polaris 280 Cleaner
    Jan 2009
    Cupertino, CA
    1,966
    Try turning off the waterfall, with the filter still running see what the pH does after an hour. Then turn the fall back on, check it again after a couple hours. If you see it even out after the fall is off, and change again after it goes back on, then the fall is really raising the pH in the shallow end and you need to improve the circulation in the pool.
    --paulr
    BBB "Intermediate Swimmer"
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Quote Originally Posted by brian7270
    stupid!
    my bad.
