Thread: Hayward Super Pump Dead?
    Connecticut
    7
    New pool owner - I went to run my Hayward Super Pump today and got a little puff of black smoke from the cable. Previous home owner spliced the power cable to either lengthen it or perhaps it was cut somehow. We've had so much rain I think the splice got wet, and now the pump won't run. Of course this happens on a Friday afternoon. Here's the problem: the water level in the pool is currently over the skimmer and we are expecting three more days of rain here in Connecticut. The water isn't as clear as I'd like it, but that's another question that I'll post with my numbers. How many days can I go without having a pump running? I have an Aquabot that is at least moving the water around. Is there anything else that I should be concerned about? Thanks
    My Pool: 30K gallons, Hayward EC65 DE filter, IG, Vinyl, 1.5 HP Hayward pump
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Hayward Super Pump Dead?
    Did you check the breakers? If tripped, make sure you tape and/or fix the splice well before reseting them.
    Mark
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    I'm in the Waterbury area ( I realize you don't want to give your address online - but if you're reasonably close, I may be able to come by and check things out 8) )
    Given the weather we're expecting, you should be good for a few days as long as your cl was good before the pump went south
    I'm going to Middletown tomorrow night for dinner with friends, if you are somewhere between Waterbury and there, I can work in a quick stop to check out your pool
    Otherwise, this is a job for the electricians!
    Luv& Luk
    -Ted
    Connecticut
    7
    The breakers are good; the GFI outlet has power. Where the power cord was spliced is charred. I hate to pay for an electrician only to find that the pump is burned out and needs to be replaced. Either way I'm probably going to spend close to the same amount. Its an older pump too.
    Ted, thank you, unfortunately I'm not located between Waterbury and Middletown. You'd be going out of your way, but I appreciate the offer.
    Eileen
