Results 1 to 7 of 7
Thread: Chlorine dispensing and Photo of my Container Pool
    Aloha, All, How do I get on top of the chlorine levels? I bought the blue floater at Home Depot and put in 3" tablets but some days chlorine is very low according to the vial test kit, so I shock the pool with 1/2# bag or so. The next day it may be too much chlorine and I pull the floater out for a day and the next day the chlorine is low again. Pool gets very little use, so the load does not vary much. Should I get a chlorinator or just keep working until I figure the floater out? Here is a photo of my pool made from a 20' steel storage container. It has a Jacuzzi on one end. And is located right off my back porch.
    thanks
    Francis
    7800 Gal. 8' wide x 20' long x 7' deep
    Hayward 1200 Cartridge 7200 GPH, Waterworks 1/8 hp 2400 GPH
    Made from 20 Container Lined with "PolyUrea/Rhino Lining"
    Workshop, welding etc,+office+living area running off grid on 10kw PV
    Feb 2008
    Denton, TX
    5,061
    Re: Chlorine dispensing and Photo of my Container Pool
    What are your test results and what are you using to test?
    Mar 2009
    Glendora, California
    169
    Hi francis, have you read pool school? If not give it a read, then read it again, and maybe one more time. Took me 3 times to start getting it. The methods you are using for maintining FC are not what this site supports. Get a good test kit so you can post numbers, which you will also be asked to do and the great folks on this site will help you figure out your problem.
    18k Inground Plaster pool / TriStar Variable Speed Pump and Controller
    48sq ft Hayward DE filter/ Swim pure Plus 40k cell / Kreepy Krauly
    Solaxx Ph-Tek
    Guest
    The link for pool school is in the upper right of every page!
    Help on my test Kit UPDATED
    Topics Merged for Consistency
    Aloha, I have a K-mart 6 in one Aquachem test kit and according to the local pool shop that knows the local water, I need to test mostly CL, PH and CYA. (it is a add 5 drops type of kit) Here are the results:
    CL 1.25 "Ideal according to kit"
    BR 3.00 not necessary but here are the numbers
    PH 7.6
    TH 350 PPM
    TA 190 PPm
    CYA = ???
    My question is
    The CYA does not even register after you mix and fill another vial and look down to see a black dot. Filling up to the rim past the "20" I still see a dot, although it is a bit cloudy. What am I doing wrong? thanks
    Francis
    BTW the kit does not differentiate between CL and TC. Why?
    Also I have been using shock and 3" tabs, since I am a newbie of 3 weeks and know better now.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Help on my test Kit UPDATED
    did you add cya or just use tabs? if it's just tabs you won't have much cya yet. you don't have a br reading unless you added bromine which I don't think you did. usually fc and tc are the same, unless you have cc's. you need a good kit and also it would be a great help if you would keep your posts in one thread so we can see the history. a mod will probably merge this back with your old thread (please).
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    The answers to the questions you posted are in Pool School. Focus on Recommended Levels, and get alot of practice with the Pool Calculator and you will figure this out.
    I recommend you order a better test kit, the one you have isn't adequate for testing chlorine levels, and the CYA level - which you need to adjust up into range - the kit only has enough testing solution for 3 tests.
    There is an article in Pool School that compares the test kits we recommend.
