Thread: Average Clorine Lost
    Rockcrawler's Avatar
    El Paso, Texas
    174
    Is there an average amount of clorine lost over nite, I know this will depend on if you have swam during the day, a cover on the pool etc..... but under ideal condtions, what would be an acceptable amount of loss?
    13,000 IG Plaster, 2hp whisperflo pump, 48 sq in pentair DE Filter, 1 skimmer, 2 eyeball outlets, 200 sq ft solar panels on second story, Auto Pilot SWG-36, Polaris ATV Cleaner
    Re: Average Clorine Lost
    You should not be losing any chlorine overnight. Pollen and debris falling into the pool can use a little chlorine, especially during the spring pollen season, but not normally very much even in the spring. Nothing else should be using any chlorine overnight.
    When measuring the overnight loss, you need to keep testing error in mind. The FAS-DPD test is +- one drop. So, losing up to 1 ppm, when doing the test so it reads in steps of 0.5, could just be normal testing variation.
    El Paso, Texas
    174
    Thanks Jason
