Results 1 to 9 of 9
Thread: Suddenly I can't post smilies
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    They aren't disabled. When I try to insert a smily the board moves up and I see the "Trouble Free Pool".
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP, 38 SF Anthony DE filter, 1 HP Hayward Super Pump
    380k BTU Raypak Natural Gas Heater (Model RP405A) and solar cover
    8 gal Liquidator w/ 12% bleach, Dolphin Diagnostic Advantage robotic cleaner. 3800 ppm salt, 50 ppm borates.
    Guest
    Re: Suddenly I can't post smilies
    They work fine for me so it must be on your end.
    Perhaps if you gave a bit more info such as your browser and OS it might help.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Go to your User Control Panel
    Then Edit Posting Defaults
    Make sure the Enable Smilies by Default is set to Yes.
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    Everything's OK in my user control. Must be a problem with IE 7 scripting. Win xp sp3. Seems that it's not my only scripting problem now. I hate Windows when it hits you suddenly. Many times it's easier to fix a pool than Win.
    Need to google "how to enable scripting in IE." I wish I could go swimming in the pool instead, because it's in tip top condition, but we're having a ***** winter in New England. Luckily I "stole" an hour yesterday before it started raining. Forget about the Sun. It doesn't exist here now. Thank you both for trying to help.
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    OK, I can do it with Firefox but my IE is bad. I enabled scripts with IE tools but no go.. Now I have to work my ***** off to fix that. Bummer.
    Guest
    switch to firefox....much better than IE7!
    Better yet, dump windoze and switch to 'nix or eComStation (OS/2)
    Pisces's Avatar
    Jun 2008
    League City, Texas
    273
    Yup, Windoze suks. I can click on the first small page of smilies and insert them no problem, but now I can't click on the page with "more smilies". So...I put my cursor over the smiley and find out the name...like "bowdown" and type colon : then bowdown and colon again...no spaces. Hit preview to see it that helps. Works for me. "punkrock"
    7,000 gal. IG gunite, SWG, PebbleSheen interior finish-Aqua Blue, 8' vanishing edge raised 16-jet overspill spa, 2 12" waterfalls, tan shelf with bubbler.
    Pentair equipment: Easy Touch 8, Intellichlor IC-40, Intelliflo VF 3050, 2.5 hp Whisperflo spa pump, 1 hp Whisperflo water feature pump, Quad 100 DE filter, Master Temp 400 heater, Legend Platinum Cleaner (3/4 hp pump). Autofill, TF-100 Test Kit w/salt and borate strips.
    Pisces Pool Build
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    Quote Originally Posted by waterbear
    The main reason I use IE is better management of favorites, or bookmarks.
    I haven't found a good add-on to handle Firefox's bookmarks.
    What is 'nix or eComStation ?
    Guest
    Quote Originally Posted by Water_man
    NON Micro$oft operating systems. 'nix is short for Linux and Unix, which share some similarities but are different.(and both can be had for free in several flavors!)
