Results 1 to 14 of 14
Thread: Dumb mistake right off the bat
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    So, I finally have moving water. Got my pH down from 9 to 7.5. No problem.
    Then the dumb mistake. When calculating my chlorine needed, I had 6% in the PC and I used 10%
    What is this going to do to my pool
    I knew something was wroing when I got to FC 25 and it still hadn't change to clear. Quit counting cause I was using up my regents.
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    Guest
    Re: Dumb mistake right off the bat
    don't lose any sleep over it. You will be fine!
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Bless your heart Waterbear. I shall go to bed now.
    Lynn
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Poor Lynn. You've been thru the ringer!
    Listen, that FC was probably consumed in an hour based on the last photo of your pool I saw. No worries.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Quote Originally Posted by frustratedpoolmom
    Thanks for the sympathy FPMom Well, I checked the water this morning
    FC 11.5
    CC .5
    So no telling what it was last night
    I'm waiting on the guys to get here and fix my plumbing and hopefully get the dirt,rocks,etc out of my pool somehow. My sitting bench and steps are brown
    I put 6lbs of stabilizer in socks last night. Still not quite dissolved.
    Do I wait a week before checking it?????
    I will check my FC hourly, right???
    Lynn
    11,969
    Wait a week before checking CYA, but after 24 hours of dissolving, add chlorine as if it was in there. So if you added enough to reach 50, assume you have 50 and refer to the CYA chart for your shock level/normal FC levels.
    Brown because of Iron? Any sequesterants/metal treatments been added?
    The more frequent your testing and bleach additions the faster the green will go away.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Good to know.
    Brown because of dirt
    Thank you FPMom
    Lynn
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    I haven't put any salt in yet, until the dirt and stuff is out of the pool, so SWG is not running.
    What do I use as primary source of chlorine in the PC????
    Do I refer to the Non SWG chart or SWG chart on the CYA/Chlorine since right now I am manually adding chlorine?????
    Lynn
    11,969
    Liquid Chlorine or Bleach,
    Non-SWG until the SWG is actually operating.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Luguid chloroine 10% right now.
    Thanks
    Lynn
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    6lbs of CYA should give me about 40 I think
    Lynn
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    They're working on the plumbing and pump is off. I need to add 1 1/2 qrts of chlorine. What should I do???
    Lynn
    If the pump will be working tonight, then wait till the pump is working.
    If the pump won't be working soon then you need to arrange for some kind of water circulation. Possibilities include a small pump, canoe paddles, brushing the entire pool twice, etc.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    He should have things running in a couple of hours. Had to redo some things that were done wrong.
    Lynn
