Results 1 to 9 of 9
Thread: Test kit for more than 5ppm Chlorine??
    Other than the ones listed in pool school of course...I am aware of those, but already have a test kit that does everything else other than chlorine past 5 (or 10 if I dilute half)
    Just wondering if there is one cheaper than buying a $70 kit for only one thing since I already have the rest.
    I would just get the whole kit, but I have seen reccos to replace all your reagents every year and don't want to waste the $$ I have already spent.
    25k gal vinyl AquaRite T-15
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Test kit for more than 5ppm Chlorine??
    You can buy the individual FAS-DPD test from both Taylor and TFTestkits.net for about $25 + shipping. If stored properly the reagents can last more than one year. I'm using my kit from last year....
    Guest
    IF and only if you currently have a Taylor K-2005 (which is identical with the K-2006 except for the chlorine test) then you can add the stand alone FAS-DPD test from either Taylor or TFTEstkits. If you have ANY other test kit (particularly ones from Bioguard and Pentair and the less expensive Taylors) you would be much better off getting one of the suggested kits. We have a lot of combined experience in pool testing and for the money (and even for much more money) nothing else is really going to give you the precision and ease and non ambiguity that the suggested kits will.
    Quote Originally Posted by waterbear
    From what I understand that is exactly what I have.
    To be sure here is the link to it:
    http://www.lesliespool.com/browse/Home/ ... 00/I/81330
    I made a mistake in trying to get the fas-dpd kit @ leslies in the first place. It is right up the street so I walked in (made my mistake) and out and didn't realize I had the wrong thing until someone here pointed it out to me.
    11,969
    Common mistake.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    yeah it is unfortunately. from what I see, the FAS-DPD addition is all you need.
    Ordered from TF testkits just a min ago.
    Thanks for the help!
    Jul 2008
    Clovis,Ca
    54
    Quote Originally Posted by danbutter
    You're not alone....
    I did(well actually the DW did) order the K2005, and thought it was THE ONE!!!
    Ordered the FAS/DPD kit from TF, all is well.
    She REALLY doesn't need to know.
    Its' easier
    C-Ya!!
    Guest
    But you guys are not going to get the cool blue box!
