Results 1 to 8 of 8
Thread: Boraxo is the algaside?
    THETOOLMAN's Avatar
    100 miles south of Atlanta
    18
    So as I read this Boraxo takes care of the algi. Is that right? if so that is way better than buying the liquid algiside
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Boraxo is the algaside?
    One thing you will learn is algaecide is rarely if ever needed if one maintains proper FC levels. Since I started with BBB all I have ever used is bleach.
    Borax does have algae-controlling properties and many users report positive results.
    Jan 2009
    Cupertino, CA
    1,966
    Boraxo is a hand soap that I remember well from my childhood, which is not the same things as the borax found in 20 Mule Team.
    --paulr
    BBB "Intermediate Swimmer"
    11,969
    I thought it was a typo.
    Guest
    No typo.
    Boraxo and 20 mule team both used to be made by US Borax back when I was a kid and there were no computers or electricity! (But at least we had Mods--the British ones, and Hippies!)
    Now Boraxo hand soap
    http://www.boraxo.com/
    and 20 Mule Team Borax (which is the stuff you WANT to use in your pool )
    http://www.20muleteamlaundry.com/index.cfm?page_id=56
    are made by Dial.
    For instructions on how to use borax as an algaestat
    so-you-want-to-add-borates-to-your-pool-why-and-how-t4921.html
    Remember, you STILL need to keep your water balanced so you still need to follow the recommendations in Pool School (link in the upper right corner of the page).
    Boraxo does have a lot of borax in it. But the other things it contains are not things you want in your pool.
    THETOOLMAN's Avatar
    18
    Yes it was a Typepo . I used 20 mule team borax The Ronald Regan stuff
    Quote Originally Posted by frustratedpoolmom
    Bob_Funk's Avatar
    May 2009
    Seattle-It really rains all the time
    113
    do you have algae in your pool?
    You have another thread where you wanted to add acid to lower pH
    post112898.html#p112898
    Borax will raise pH, is that why your pH is high you added borax to fight algae?
    If you are adding borates you should shoot for about 50ppm
    Here is what you need to read if adding borates to your pool
    I consider myself very lucky I found this site before the pool store found me-pool owner since Nov 2008- Stunningly clear 17,000 gal fiberglass pool, thanks to this site, installed in 1982-24" 3.1sq. ft sta-rite sand filter, 1 hp - 2 speed wisperflo pump-WFDS-4
