Thread: Help me improve my heater plumbing
    kevreh's Avatar
    Jun 2007
    Annandale, VA
    404
    Hello-
    I need to update the 1-1/2 PVC 80 nipples coming out of my heater. The connection between the nipples and the schedule 40 pipe leaks. Looking at the picture, any thoughts on improving this? For the pipe closest to the camera, I was going to add two 90-degree elbow to make things "cleaner" and the flex pipe isn't at a wierd angle. For the pipe firthest from the camera only thing I can do is extend it a bit (2") so it clears the other pipe better.
    Thoughts?
    TIA,
    Kevin
    [attachment=0:2lqvy46v]heater.jpg[/attachment:2lqvy46v]
    16x32 Concrete IG 24k Gallons
    Equipment: Carvin 525sf Cartridge Filter, Jandy Gas Heater, Vortex Solar Panels w/solar valve, 1hp Hayward Pump with 3/4 HP AO Smith 2 Speed Replacement Motor, Aquarite Saltwater Cell, Polaris 280 Dolphin Active 20 Robot
    Automation: Hayward Prologic Controller
    Re: Help me improve my heater plumbing
    The short pipes coming out of the heater should be CPVC, which deals with high temperatures better. From the photos it looks like the current ones are CPVC.
    Your plan sound good.
    Instead of two 90s, you could use a 90 and a 45. It is only a tiny water flow improvement, but it isn't any extra work or cost.
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    I would get rid of the flex between the heater(output?) and the SWG. You could (from the looks of the picture) make it work with two 45's or two 90's. The other, shorter piece of flex looks fine but you could also replace that with a 90 or 2 45's. Then again, maybe I misread your post and that is exactly what you're going to do (sounded to me like you planned to leave the one going to the SWG alone except extend it?).
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
    kevreh's Avatar
    Jun 2007
    Annandale, VA
    404
    Quote Originally Posted by launboy
    Adam
    Yeah, that was sort of what I was thinking. I thought the flex pipe would save some pressure loss due to less 45/90's....but now that I think of it adding a few 90's probably won't make a difference.
    Thanks
