Thread: Backwash valve
    Backwash valve
    Is it possible to have a permanent pipe connected to the backwash valve on the filter that is buried underground and runs to the street drain?Then you would not have to connect that **** blue backwash hose.Is this something that has been done forever?
    20K gal.
    Hayward S-244T sand filter
    IG vinyl
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Backwash valve
    yes you can...just use pvc like the rest of your plumbing
    Re: Backwash valve
    That is what I was thinking it just makes perfect since to me.Thanks
    20K gal.
    IG vinyl
    DaveNJ's Avatar
    Toms River, NJ
    520
    Re: Backwash valve
    Also include a union, in case you have to remove the valve. Here are pics how I terminated mine at the street.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    no-mas's Avatar
    Jun 2008
    FL
    405
    Re: Backwash valve
    Dave -
    That is similar to my setup - but my pop up flies off when I backwash or drain to waste... How do you prevent that from happening?
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    DaveNJ's Avatar
    Toms River, NJ
    520
    Re: Backwash valve
    I screwed the green part to the base part. My total pipe length is about 140'. The 2" pipe goes to a 3"x 3' pipe connected to the pop-up.
