Thread: Is check valve at backwash port needed
    Krickett's Avatar
    Jul 2008
    Arlington, Texas
    82
    I'm replacing my filter with a side mount sand filter using a 7 position multiport valve. My current system had a DE filter with a backwash tank and between the filter and tank there is a check valve. I have since removed the tank and backwash to the sewer system but since I'm replacing these things I was wondering if I really need the check valve since the multiport valve is above the piping outlet. I hope that is clear.
    21k gal, plaster IG pool with spa
    Main - 1 skimmer, 1 main drain, 3 returns, Spa - 1 drain, 4 returns
    WhisperFlo Dual Speed WFDS 1.5 HP pump
    S310S 30" sand filter
    Polaris 360 pressure cleaner
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Is check valve at backwash port needed
    No, you don't need it.
