Thread: Polaris 280 conversion
    May 2009
    Santa Barbara, CA
    Hi all,
    Looking to eliminate the booster pump. Wanting to replumb this system to run off the filter pump. Any ideas?
    Re: Polaris 280 conversion
    I wouldn't do it. You could plumb your circulation pump to feed the pool cleaner return but most of the pool cleaner return lines are 1" and restricting the pressure side of your circulation pump down that far will be very hard on it and wear it out prematurely. You'll negate the savings of not running the booster pump pretty quickly.
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
    booster pump models of cleaners are high pressure but lower flow. Non booster models like the 360 are lower pressure and higher flow (gpm)
