Thread: Rust Stain on Liner?
    Sallie's Avatar
    May 2008
    Columbia, SC
    103
    I have an area in the middle of the shallow end on the pool bottom that looks like several rust spots. I got a new liner last year, and I'm not sure when I first noticed the spots, but it was sometime this season. We did not cover our pool over the winter. I don't remember seeing anything sitting on the pool floor, but the water was not clear at all most of last season and the beginning of this one.
    Sallie
    25 K gal., vinyl IG, Hayward 3/4 hp pump, Hayward Pro Series S-220T 18" sand filter, full sun all day, no main drain, Taylor K-2006C and K-1766 test kits, Circupool RJ45 SWG - Columbia, SC
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Rust Stain on Liner?
    If it's rust spots, a vitamin C tablet will lift the spot easily.
    Sallie's Avatar
    May 2008
    Columbia, SC
    103
    I have Vit C tablets. Would it rest on the bottom or will it try to float up, or would I need to put the tablet in something and place it on the bottom? I don't understand how a rust spot could have gotten on the liner there. We have an extra piece of the liner, and I told my husband that maybe we needed to cover that spot.
    Sallie
    11,969
    It should change rather quickly, if you just hold the tablet on the spot.
    Sallie's Avatar
    May 2008
    Columbia, SC
    103
    Well, I got in there today. The tablets fell to the bottom, and I just used my foot to position them. It took a while for the spots to go away, but they are almost gone. The tablets dissolved, and I have some more out there now. One of the places looks like it has a tiny slit in it. I'm really not losing any water, but I'd like to make sure that's not a hole. If I stand over it and drop food dye there, will the dye go to a hole on the bottom through about 3 feet of water? You may say get under water and inspect it, but I wear glasses and would not be able to see. My family is all in the same boat.
    Sallie
    11,969
    I'm not certain how the dye test will work with a hole...I do know you have to be closer - like an inch away.
