Thread: Bricks OK for steps??
    irishal's Avatar
    May 2009
    Edmond, OK
    Are bricks ok to use as weights to hold down the steps in an AG pool? We have Biltmore steps and there is a shelf to place weights of some kind to weigh them down. I've read the posts about PVC piping etc...etc...but just wondering if brick/concrete blocks are ok?
    30ft AGP
    2hp pump
    TFTestkits ,Pool Calculator, Pool School
    DaveNJ's Avatar
    Toms River, NJ
    Re: Bricks OK for steps??
    Some people have filled pieces of PVC with cement and end caps. Water will not effect them and rounded ends, so no sharp edges.
    Look here there is a picture down the page.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    I went out and bought two bags of playsand and used two large bags, almost like large ziplock bags and sealed them up. They fit under the steps well and do the jobs. I like the fact that there is nothing to damage the liner and it was cheap.
    Lomart 21ft round 11,000 gal 52"
    Hayward EC40 Perflex DE filter
    1hp Hayward Powerflo Matrix with micro timer
    Pool Rover JR ABG pool Vacuum (The best)
    Back up pump and filter
    Spectra 3 sand filter/ Promega 1 horse pump with timer
    NWMNMom's Avatar
    Waaay NW MN
    I would not go with bricks or concrete blocks of any kind. First off, the raw concrete from big cinder blocks can leach out an acidic substance depending on what exactly was used in the mix, but even more importantly the rough edges can wreak havok on the liner if they scrape or fall on the side or floor. The sealed pvc prevents both of the aforementioned things from happening.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
