Results 1 to 8 of 8
Thread: If you have a TFP (perfect chemistry etc)...
    How much bleach are you adding per day? ARE you adding it on a daily basis?
    I'm just curious how much bleach you go through on the BBB method.
    27' round AG, sand, Ohio, well water, 19,000 gallons approx., New owners to the pool.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: If you have a TFP (perfect chemistry etc)...
    Well, the company line is 2ppm is average.
    I myself use about a gallon of bleach a week, if that. My usage averages lower than most, tends to be .5-1ppm per day, but I leave my solar cover on when it's not in use and my swimmer load is very low, we've only been in twice since opening (stupid weather).
    I test and add bleach every other day, during the heat of the summer. Sometimes daily if I'm motivated to.
    Fayetteville, Arkansas
    220
    Well, it depends on several things -size of pool, bather load, rainfall, CYA level etc.
    I would say on average I add about 2 quarts a day, sometimes 3 to maintain target FC for my pool size and use.
    20x40 30,000 gal IG Liner, Pentair II Sand
    I use about 3 quarts per day too. I have three kids who are constantly in the pool along with their friends and we also get tons of sun. I have an 8 gallon liquidator and fill it up about every 1.5 weeks.
    20 x 40 IG vinyl liner, 2 skimmer, 8 gallon liquidator, in Tennessee
    May 2009
    Dallas, TX
    784
    Quote Originally Posted by frustratedpoolmom
    Similar situation here...low usage, pool gets a lot of shade, so my chlorine usage is low like FPM's. I use about 1 quart a day. That will go up if I ever get a chance to actually swim in it...
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    Cherie's Avatar
    Jul 2008
    Wylie, Texas
    506
    Mike, you can go stand in the corner now!
    This is our first season with a solar cover. So we've only been adding one quart (or less) of 10% daily. So far this season, also a light swimmer load, except for today. And I ended up using 2.5 qts tonight, just to get it a little higher so I can skip a day. But I'm also experimenting with our CYA and have it between 15-20 (will probably raise it to 25-30 soon).
    32x16 buried Doughboy, 4' shallow - 7' deep
    Pentair Dynamo 1 hp, 2-speed - Pentair 150# SD40 w/zeolite (75#)
    One skimmer/two returns/Aquabot Turbo T2
    Jan 2009
    Cupertino, CA
    1,966
    I've been running at about .5ppm per day, 2 cups 12.5% every other day. With a cover and nobody in the pool (expect that will change this weekend).
    --paulr
    BBB "Intermediate Swimmer"
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    I have to replace 1.5 - 2.0 ppm every day. For my pool that amounts to 3 or 4 quarts per day of 6% bleach. That has been very constant for the last 2 months.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
