Thread: Adding DE to Sand Filters
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    12,093
    I think perhaps consider updating the article to specify Pool Grade DE?
    Kannapolis, NC
    89
    Re: Adding DE to Sand Filters
    But where can you find a small amount of DE for our needs as the smallest amount I have seen is 25 lbs.
    _________________
    My Pool:
    Foxx Pool Grecian style 19' X 39'
    27k, with a 300# sand filter
    Jan 2009
    Cupertino, CA
    1,966
    My local PS has a 10lb package. Probably not going to find any less than that. You do need to replace it after every backwash so 10lb is 20 doses. It's not all that expensive though, I just bought 25lb for about $20.
    --paulr
    BBB "Intermediate Swimmer"
    Apr 2010
    hurricane deep south
    24
    i agree! i am familiar with de in the garden - it comes in smaller amounts and spent some time this evening making sure they are different. perhaps also a vice versa mention that pool grade is a respiratory hazard and should not be in the garden......shudder.
    33K IG 1967 45' X 20' Roman 4-8 ft plaster/gunite. Triton Sand, 1.5 HP pump. Indoor with Screen Atrium top. Bought a Swamp with Nails Glass and Trash with An Algae Encrusted Astroturf Surround. On par and thankful to TFP since 4/2010. A good test kit is your friend! Using a K-2006, refills from TFTest kits.
    The respiratory hazard info was already there. I just added a note that gardening DE is not the same stuff and is not suitable.
    Apr 2010
    24
    that was quick! hopefully i won't run into any more scary posts about that!
