Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Plumbing screwed up???Need help
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    These guys were used to plumbing the booster pump after the SWG. I guess I took them out of their element when I told them to plumb it before the SWG. Well they also plumbed it before the filter Isn't that wrong????
    Help please. Electrician is suppose to be here in a.m.
    I just want to cry
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Plumbing screwed up???Need help fast
    The downside of course of plumbing before the filter is that it will send dirt and small debris to the cleaner where it might clog the cleaner. You're right in that it is best to plumb it between the filter and swg although after the SWG shouldn't be a big problem just not ideal. I can't tell from the pictures but it looks like he could of moved the equipment away from the edge of pad so there would have been more room for the booster between the filter and swg. I would make him redo it.
    Also, it is a good idea to have at least 10" of straight pipe before the pump basket on the suction side.
    Mark
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    I also asked that there be at least 12" of straight pipe going into the main pump and there is only 8.5". Is that something I should address??
    My pad is 6x8. Here are a couple other pics. If you notice, the nut I have to get to to losen the filter lid is towards the back of my future building, along with the pressure gage facing that way also. I guess there's not much I can do about that is there??
    Could you describe to me what could be done, as I don't think they will offer any suggestions. They will want to leave it as is I'm sure.
    Thanks
    Lynn
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    I guess I'm so mad I didn't finish reading your post about the 10" before I posted.
    Lynn
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    I guess when I asked that the plumbing be stubbed up on the back side of the pad, I didn't realize the filter would be facing backwards.
    Lynn
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    O.K. I'm going to think out loud here Bear in mind I am no plumber.
    Could I put a T at the pressure outlet of the filter and connect the suction to the booster pump to it??? The filter could be moved closer to the corner of the pad.
    Also, to get a longer pipe going into the main pump, could some of the 2 suction pipes be shortened???
    I hope I'm making some sense
    Lynn
    mas985's Avatar
    Pleasanton, CA
    11,742
    Yes you could put a tee after the filter for the booster but you have so much room on that pad, I really can't understand why the plumber did what he did. There is plemty of room for the booster and for 10" of pump suction pipe.
    Mark
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    I'm with you Mark. So my thinking would work,(all of my thinking)?? That seems to be the easiest way to fix the problem. But I don't want to compromise my equipment with the easy way out. Other suggestions?????
    Lynn
    Mar 2007
    Coastalish 'down easter'
    4,160
    Hi Lynn
    Mark's got you covered on the plumbing issues (and better than I could :P )!
    The band clamp and top of the filter and the orientation of the top 1/2, including where the pressure gauge faces and the air valve points, can be changed at your leisure 8) All you have to do is remove the band and turn the top where you want it to face and then reband itso the bolt is in a good position for you
    Are you up and running?
    Luv& Luk
    -Ted
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Quote Originally Posted by waste
    Hi Lynn
    Hallelujh on the filter position No, not running yet. The electrician will be here in the morning. That's why I needed help so quickly on this plumbing issue.
    If I do has I have thought out, it should not mess up the electrician, right?? But should the plumbing be complete before the electrical is hooked in??
    Lynn
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    In the pics, is there enough straight pipe going into the booster pump???
    Lynn
    mas985's Avatar
    Pleasanton, CA
    11,742
    Orthofish, is there any reason why you cannot move the filter and main pump back on the pad to give yourself more room. Separating the filter before the swg and the pump between the tee and basket, should allow you to move both away from the other plumbing to give you enough room for a tee between the elbow and SWG and 10" of suction pipe. The rest of the plumbing would not need to be changed except for the booster. The SWG and filter fittings will accept a 2 1/2" coupling so that can be reused if you want.
    Mark
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Took me a few reads before I got what you are saying Yes, Mark, I think that would be the way to go.
    Thank you so much. Any other advice gladly accepted.
    Lynn
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Now they're telling me the reason they did it this way was so the booster pump wouldn't steal too much water from the rest of the system when running????? Not sure I'm buying that.
    Any thoughts???
    Lynn
    Round Rock, TX
    529
    Quote Originally Posted by orthofish
    Any thoughts???
    They plumbed it before the filter instead of after it so that the booster pump would not steal the water from the rest of the system? That makes no sense at all.
    What water goes into the filter will come back out. The location of the booster pump, as long as it is post main pump, and before any of the water returns will not affect the rest of the system.
    Sounds like they just don't want to change it.
    My cleaner was originally plumbed pre-filter and I did have to run the filter more to get the water clear as the booster pump was pumping dirty water back into the pool. I also had to constantly clean the filter in the cleaner line. I'd have them move it post filter.
    dave
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    So when the water comes out of the filter to the T we're talking about, there will be enough to hang a left turn , to the SWG and all the other returns and also to the booster pump if it is running???
    Lynn
    Round Rock, TX
    529
    For me the order of importance would be.
    1. post filter
    2. pre-SWCG
    If they could take the elbow post filter and turn that into a tee with one end hooking up to the SWCG and the other to the booster pump that should work fine.
    Not sure what tee your talking about.
    But if you tell them post filter and pre-swcg they should be able to figure that out.
    dave
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    The T you're talking about is what we've discussed earlier in this thread. So there would be enough water coming out of the filter to make everything happy?
    Lynn
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Quote Originally Posted by lovingHDTV
    dave
    I did tell them that and they think I'm and idiot or they just don't want to change it.
    Lynn
  20. Back To Top    #20
    Round Rock, TX
    529
    dave
    I had to replumb mine from pre-filter to post filter. It was not fun and I did not like putting unfiltered water back into my pool via the cleaner. Did not make sense to me. I'd push the issue till they fix it.
    If they put it post swcg that would be acceptable for me, just not optimal. Mine in plumbed post swcg now.
    dave
