Results 1 to 17 of 17
Thread: adjusting ph during conversion
    new convert here.... We have started our conversion and are only 3 days in as of today. We lowered the pool to fix a small leak and refilled. Using the pool calc. and assuming zero FC we added 532 oz. of 6% bleach. I need to say now we only have a cheapo test kit that tests only for chlorine/ph. We are waiting on our new TF100 to arrive(today? tomorrow?) Anyway, the chlorine was way off the chart. We added more later in the day. It appeared to be in the 2-3 range before adding. We did experience greenish/brown water but not as bad as some of the pictures we've seen here. We've monitored pretty constantly for the last 3 days and added a total of 12 gallons so far. After one day it started clearing to the blue/hazy stage and before dark actually looked clear. This morning added to the yellow to orange color(cheapo) and just got home and checked it,in the rain. It's down to the .5-1 range. We're adding more bleach to take it back up but my question is(finally) My PH is creeping up (8.2+), started at 7.4. Can this be from aeration? Do I adjust this during the conversion process(add muriatic acid) or just continue pouring on the FC until it holds? I will post full test levels as soon as I can. Great Site. Thanks so much.
    Thanks, Andy
    AG; 17,100 gal.
    Hayward RG 450, 3/4hp; DE Filter
    Aquabug
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: adjusting ph during conversion
    Only test and adjust PH when the FC is below 10. Above that and the PH results will read false-high.
    If the FC drops below 10 and the PH is above 7.2, lower it back down with muratic acid to 7.2.
    Welcome to TFP!
    To add to what frustratedpoolmom, since you can't measure FC levels around 10 just yet, only adjust the PH when FC is down around 3 or lower, just to be completely sure.
    New question.... Last night added 460 oz of 6% bleach and brought FC up above what my cheap tester could read. should have been close to 15(pool calc.) Checked it again this morning and it appeared to be still above 5 on the tester. Added 182 oz. of 6%(all I had) and went to work. My wife called and said we received our TF100 kit(yeahhh). When I came home I tested and results follow. New question is : can i really use up all my fc during a completely overcast day? We are working on posting pictures but for now I can just say the pool looks great and it seems weird that it needs/consumes that much???
    Test Results(45 min.after adding bleach)
    FC= 17.5
    CC=0
    PH=8.2+ (FALSE?)
    T/A=570 ( WHAT THE ? )
    CYA=0
    Will continue monitoring/adding bleach. any suggestions? Thanks to all.
    Also, how to change username? Need a cooler handle. Thanks
    Thanks, Andy
    AG; 17,100 gal.
    Aquabug
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by andy leonhardt
    FC= 17.5 Aim for FC of 15 and try not to overshoot.
    CC=0
    PH=8.2+ (FALSE?)Yep, false because of your high Fc. Retest pH afte FC drops below 10
    T/A=570 ( WHAT THE ? ) Retest and this time wipe the bottle tip with a damp cloth in between drops.
    CYA=0 Should be zero. Don't use your reagents on this test yet.
    Want a cooler handle? KWYM 8) Send a PM to JasonLion BUT, fair warning, Jason is up to his neck in alligators at the moment working on the site! It may be a while before he is able to respond! Thanks
    You're done SLAMing when:
    New results 5 hrs later(11pm):
    FC=11
    T/A=300
    Check again in the morning.
    Thanks, Andy
    AG; 17,100 gal.
    Aquabug
    Your doing very well!
    Tonight, if you are still awake, or tomorrow night, you should do an overnight FC loss test. That will give you a much better idea of how close to done you are.
    Thanks again for all the help!!!!!
    8am test results:
    FC=9
    CC=.5
    T/A=260
    Dropped by 2ppm overnight, am going to add to 15ppm again this morning and check again later tonite. This site and the new test kit are awesome!!!!!!
    Thanks, Andy
    AG; 17,100 gal.
    Aquabug
    Good, you are very close to done.
    11,969
    Big difference on the TA result! Still high, so after you get your FC holding, complete the conversion, change the filter media, add CYA....next on your list will be lowering TA.
    Howdy!!!! am in a good mood because finally a little bit of sunshine while testing the waters. In my search today for Walmart bleach(3 stores-2 182 oz jugs total ) I became frustrated and resigned to the fact I was going have to buy more expensive bleach. While I was at Meijer I decided to just look in their pool dept. to check on the price of liquid chlorinator. THEY HAD 10% CHLORINATOR FOR $9.99 A CASE(4 gal.) Hopefully it is fresh and I got a deal. Here's tonights test results:8PM
    FC=0
    T/A=250
    I'm going out to add the new chlorinator to 15ppm. Last night only lost 2ppm. If I do the overnight loss test and only lose 1ppm am I done with the conversion? It seems odd as I am at zero now???? Help!?
    Thanks, Andy
    AG; 17,100 gal.
    Aquabug
    11,969
    It's not odd at all, perfectly normal. You can move into the final stages if your FC holds overnight.
    Had major storms last night. Tested before bed and was at 16ppm (oops-I know I need to try not to overshoot) We did put on our reel and solar cover last night so I kind of expected a loss due to last years baq-klingons. couples with the rain,lost 3.5ppm last night. Expecting more rain today. Will monitor more.... Thanks to all
    Thanks, Andy
    AG; 17,100 gal.
    Aquabug
    I AM SICK OF RAIN. Brought FC up again in the evening to 16ppm and really believe I'm at the point to start completion of the conversion but noooo, it has to rain all &%*$ night again. FC this morning is 13.5 I'm getting frustrated because it seem like we made so much progress the first few days but the last 3 have been just dumping bleach to make up for the rain I'm sure tonight i'll be at 0 again. Can I put in any CYA at this point to save some FC? Thanks all!
    Thanks, Andy
    AG; 17,100 gal.
    Aquabug
    11,969
    Well, I would think you are ready to move on to changing out the filter media and adding CYA. But Jason is the one we should verify this with....hang tight.
    Alright.... back on line.did not post yesterday(Daddy Day) Lost only .5 FC overnite on sat. nite. CC still.5 PH 8.2+ T/A 260
    Cleaned out filter(rinsed off cartridge,soaked in muriatic/water solution), rinsed again and reassembled, added new DE
    Added 4 lbs cya/stabilizer(sock) Did not attempt to correct anything else. Wanted to see how the CYA affected FC loss.
    Tested today@9:30pm(daughters softball game after work-we won) Test results as follows:
    FC=1.5
    CC=.5
    PH=8.2
    T/A=230
    CYA<20 (still a partial sock left)
    Added 53oz. of 10% bleach(shooting for 4ppm)
    Added 62oz. muriatic acid(going for 7.8ppm)
    Pool calculator said to lower ph to lower T/A and aerate to bring back up PH. Will lowering the PH bring down my T/A or do I need to do anything else? Water is clear and sparkling The sides and bottom seem to have a"graininess" to them. You can rub it off and we(the wife) will brush and vacuum it all tomorrow. whats that from?
    Thanks for all the help.
    Thanks, Andy
    AG; 17,100 gal.
    Aquabug
    You should be lowering your PH much lower than 7.8. 7.8 is the highest you should allow the PH to get. Given your high TA, you should be lowering the PH to around 7.2. Remember not to try to measure PH when the FC level is high.
    There are full instructions on lowering TA at Pool School.
