Thread: Pump problems.
    May 2009
    Lombard, IL
    Pump problems.
    I used to have a hayward 1 speed, 2HP pump for my 21' round above ground pool. It was causing issues with my filter/plumbing (leaks) because it's apparently oversized for the filter/pool. I've since purchased a replacement Hayward 1 speed, 1HP pump and when I go to turn it on it just humms and I have to smack it a few times in order for it to start working. Any ideas on why this would be or how I can fix it. The only thing I did was install the timer from the 2HP motor on to the new 1HP motor which is part of the aggravation. I can't really use the timer because when the timer turns it on it sits there and humms and no one is there to smack it!
    Any ideas?
    10K Gallons
    Hayward Cartridge Filter
    Above Ground
    1HP Pump
    Re: Pump problems.
    I would double check the electrical connections then return it for another one. Anything new should not have to be coaxed to work.
