Thread: Convert Super Pump to dual speed possible?
    Apr 2009
    Western Kentucky
    31
    My pump in my Hayward Super Pump fried yesterday. I pulled it out, and was going to take it to have it rebuilt. But is there a direct replacement for these Super Pumps that are dual speed
    I would just rather buy a motor, and swap it into the housing then to spend $500 plus on a whole new dual speed rig. But a rebuild is only $80. If I can't keep it within reason, I will just go that route.
    The housing has a number of SP2610X15, and the number on the motor is C4BL2N134.
    32'x16' vinyl in-ground. 8' Deep, 3' Shallow
    Est. 21,000 gallons
    Hayward 300lb Sand filter w/SP-0714T valve assembly.
    Hayward 1 1/2HP Super Pump swapped with a A.O. Smith Dual Speed Motor.
    1 Skim, 1 Drain, 2 Outlets
    Re: Convert Super Pump to dual speed possible?
    A "56c frame" two speed motor will bolt right up to your rig.
    Dave.
    Apr 2009
    Western Kentucky
    31
    Ah so that's the magic number. 8) Now I just got to hope around the net and find one.
    Est. 21,000 gallons
    Quote Originally Posted by gsxr1181
    I actually JUST did the same thing! Ordered a pump from a1pool. Took a while to receive as it was special order.
    I basically removed the old 1.5hp service factor 1.1 (SHP 1.65) motor that was using 8.2amps at 230v and replaced it with a AO Smith 2 speed (1hp, SF 1.65 for SHP 1.65 on high) Even on high it only uses 7.2amps at 230v and less than 4amps on low and really moves good water on low!
    Total install time was less than 1 hour.
