Thread: How to install multiple returns?
    So it's probably too late for this year - but I think I do want to add another return - but how does that work? I'm asssuming you'd want it on the other end of the pool (we have a 21x41 aboveground pool) because that end doesn't seem to get much action!
    Do you just put a whole nother filter/pump set up down there? Or run a line all the way from the pump/filter at the other end?
    If anyone can tell me about multiple returns, I'd appreciate it. I did a search and didn't come up with anything.
    21x41x54" AG Artesian Seville II
    Installed around 2004 - we moved here in 2008
    23,000 gal
    Hayward SwimPro 256T Sand Filter
    1HP 2speed Hayward Power Flo Matrix
    (and have 2HP Hayward Swimpro and a 2hp 2speed Waterway Hi-Flo pump as back up also!! lol)
    No heating - other than Solar SunRings
    Central IL
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: How to install multiple returns?
    IG pools usually have multiple returns, and it's not complicated. You just run another line, but for best performance you want the piping to each return to be the same length. That means that for two returns you run a line to the mid-point and then from there to each return. If you don't equalize the runs, the return with the longer run gets less flow.
    Mar 2007
    Coastalish 'down easter'
    4,160
    John, once again , beat me to the best answer . There is, however, another option You can install a 3 - way valve on the return line and keep the 2 returns separate and then regulate the flow to them via the valve
    Do the additional valve as will be best for you and your requirements
    Luv& Luk
    -Ted
