Thread: What Cleaner is Compatable w/ Aqua Genie?
    reallytiredteacher's Avatar
    May 2009
    Southern Missouri
    Help!!! I bought the Polaris 360 for our new IG with vinyl liner that we are installing ourselves. We have an Aqua Genie and 2 main drains in place of the traditional skimmer and several returns. The Polaris 360 apparently runs on a return and since we don't have one I would like to sell this one and will need a new one in a week or two.
    What IG Cleaners will work with the Aqua Genie??? Help...I'm a NEWBIE ((in need of a cleaner!!!))
    22K gal IG Vinyl 18'x36' rectangle (Hydra Pool Kit, Homebuilt DIY Spring09) 8' deep end
    Aqua Genie (No Main Drain, No Separate Returns), Hayward 1.5hp Pump, 24" sand filter & 2" Pipes, Jandy WaterColors LED Light, Flyte DeckII/FibreDive Board
    :sun: Added for 2010~ SWG CompuPool CPSC36, "The Pool Cleaner 2x" suction cleaner, PICS of our DIY build, and our DIY Lime Green SLIDE refinishing project!
    Re: What Cleaner is Compatable w/ Aqua Genie?
    I have a Aquabot Turbo T4 RC. Other than occasionally getting stuck on the main drain, it cleans the floor and sides (all the way up to the water line!) well. I have only used the RC feature a couple of times when I wanted it clean quickly before company. We built a 75' lap pool, with only two ladders (no stairs, benches, etc.), so maybe that is why it works for me. After 3 years, the pump had to be repaired (still under warranty at a percentage) and I thought I would go crazy hand vacuuming while it was gone! I almost kissed it when it came back. Lol! I would not want to be without this machine! I guess you're a lover or a hater. (originally posted under "dump..robot").
    I also have 3 aqua genies, only one main drain.
