Thread: How do these # look?
    FC 4.5
    CC 0.0
    PH 8.0
    TA 260
    CH 110
    CYA was 30 2 weeks ago.
    Thanks Mike
    gunnite bottom and fiberglass walls that have been coated with epoxy paint. Approx. 24000 gallons, sand filter.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: How do these # look?
    Tolerable. You'll want to lower your pH into the 7.4 to 7.6 range. You might want to consider following the TA lowering advice in Pool School http://www.troublefreepool.com/pool-...l%20alkalinity which will make your pH more stable.
