Results 1 to 8 of 8
Thread: Sanitary Help
    Sep 2008
    Jacksonville, FL
    105
    Sanitary Help
    OK... Not really sure where this falls so I thought I would post it here.
    Tonight while swimming, my 5 year old had a little accident in her pants. She went #2 a little bit. Being this is very unlike her, I am not sure what needs to be done to keep the pool sanitary. Any advice is welcome!!
    Thanks!!
    16,500 Gallon Plaster, Pentair WhisperFlo WF-26 1 1/2 HP Up-Rated Pump, Pentair Clean n Clear 150 Cartridge Filter, BioGuard Mineral Springs MS-10 SWG, Hayward Navigator Cleaner, TF-100 Test Kit, Apollo Magnetic Stirrer
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Sanitary Help
    If it was solid, keep the FC elevated by 3-4 extra ppm of FC, and leave the filter/pump running overnight - if it was loose, I'd shock it and leave the pump running.
    Sep 2008
    Jacksonville, FL
    105
    Re: Sanitary Help
    OK... Thanks. Nothing got in the pool as it was contained within her bathing suit. I brought the chlorine up to 10 today (since that is all I had of the liquid) and ran the filter all night. Hopefully that will do the trick.
    Sep 2008
    Jacksonville, FL
    105
    Re: Sanitary Help
    Well she did it again.... Her mom gave her a laxative and it hit her all of the sudden. This time it was loose!! I vaccumed everything that went to the bottom then removed the filter and put a different one in. I then dropped in 2 1/2 gallons of chlorine. I left the pump on all night.
    Is there anything else I should do? Is there anything I should not have done? How long should I hold the FC up and at what levels?
    Thank you!!!
    11,969
    Re: Sanitary Help
    Nope, shocking is the thing to do. Keep it at shock levels for at least 24 hours and do an overnight FC loss test.
    Overnight FC Loss Test
    Sep 2008
    Jacksonville, FL
    105
    Re: Sanitary Help
    Ok... Well I added 2 1/2 gallons which didn't seem to be enough so I added another 5 gallons of chlorine. After acouple of days I tested it just to see where it was. I was sitting at 5ppm so I went and got another 5 gallons and let it circulate for 24-48 hours with the pump running 24/7. I tested last night about 9PM and it was at 18ppm and then I tested again this morning at 6AM and it was still at 18ppm. My SWG was turned off too.
    It has been almost a week and 12.5 gallons of chlorine later, so am I in the clear now?
    Thanks!!!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,418
    Re: Sanitary Help
    Sounds like you should be good now. New rule, "no swimming until 24 hours after last laxative dose"!
    Love TFP? Become a
    TFP Supporter!
    Sep 2008
    Jacksonville, FL
    105
    Re: Sanitary Help
    Good Rule!!! If I could only get my ex-wife to inform me of these things. Lol
