Thread: How many gallons is my pool?
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    According to the PC my pool is 21,800G. I used 15x37x5.2. The PB says it is 19,000G
    according to his sheet of all the pools they sell. I hope to have equipment hooked up this week so I can start adding chemicals. It is a green monster right now Which number should I use? In reading, it seems I should be pretty accurate when adding chems.
    I've updated my sig to split the difference right now.
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    Guest
    Re: How many gallons is my pool?
    Call it 20K gal and go have a cool one! It will be close enough for government work, trust me!
    30,414
    Hi, Lynn,
    I'll bet your close with 20k. If you feel the need to be more precise, 5.2 average depth seems a little agressive but I don't know the config of your pool.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Thanks guys.
    The configuration is in my pool build, to which I will add some pics tonight I hope
    Guess I need to quit being so an#l
    Lynn
    Jan 2009
    Cupertino, CA
    1,966
    1) Pick a number.
    2) Use it for a while. Notice if you tend to overshoot or undershoot your chems.
    3) If you overshoot, go smaller; if you undershoot, go bigger.
    4) Repeat until you don't over- or undershoot.
    The calculations are an initial educated guess, that's all. I went three rounds of this process before I got a number that works pretty well.
    --paulr
    BBB "Intermediate Swimmer"
