Thread: Algae
    Jun 2008
    Avon Park, FL
    15
    Algae
    I have been adding the daily 2 ppm of bleach every day for the last month or so but I am starting to see some signs of algae trying to develop. I live in FL and it has been hot for the past week or so. How can I keep this from happening? I try to hit the target of FC around 7 or 8 but it doesn't seem to be helping and I am running the pump during the day as suggested. My current readings are the following:
    CYA 50
    pH 7.6
    TA 120
    FC 3 or 4 by time I get home.
    Thanks for any help I can get.
    15200 Gallon, Vinyl, Cartridge Filter 100 GPM, SWG
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Algae
    Are you brushing your pool weekly? Is this the kind with the inflatalble ring? Be sure to clean under the ring, lots of gook can build up there and allow algae to take hold.
    Try running with a slightly higher FC level, and run the pump a few hours longer than you are now.
    Is your FC holding overnight? If not, you should shock. Be sure to brush/clean all the surfaces while at shock level.
    When is the last time you changed the cartridge?
    Fayetteville, Arkansas
    220
    Re: Algae
    Does your FC number hold overnight? My guess is that you haven't totally, completely killed off ALL algae in your pool. Others with more experience will come along to offer a more experienced opinion. Hang in there!
    20x40 30,000 gal IG Liner, Pentair II Sand
    Guest
    Re: Algae
    Quote Originally Posted by pjohnson73
    CYA 50
    pH 7.6
    TA 120
    I know the kind of almost daily rains you get near the lakes there in central FL. (We got them in s. FL when I lived there and we get them in N. FL where I live now and I've been to Avon Park quite a bit because I had friends that lived there.) Are you taking that into account and adding extra chlorine after it rains?
