Thread: What is the best pump size for my pool
    Krickett's Avatar
    Jul 2008
    Arlington, Texas
    82
    Sorry to be such a pest but I want to do things right as I am replacing the filter and pump. I've posted a few questions concerning filter size but the response I got was based on the pump which I've decided to also replace so I want to make sure the pump is the right size. Originally, the pump was a 2hp. I replaced the motor 2 yrs ago with a 1.5 hp but I'm wondering if that is still too big. What is the best sized pump for these measurements?
    Size: IG pool with spa (about 21000 gallons), size is kind of a figure 8 shape of a rough estimate guess of 20-25' wide x 35-40' long
    Input: 1 skimmer, 1 spa drain and 1 main drain, 2" plumbing
    Output: 3 pool returns, 4 spa returns, 1 pressure side cleaner outlet, 1.5" plumbing
    21k gal, plaster IG pool with spa
    Main - 1 skimmer, 1 main drain, 3 returns, Spa - 1 drain, 4 returns
    WhisperFlo Dual Speed WFDS 1.5 HP pump
    S310S 30" sand filter
    Polaris 360 pressure cleaner
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: What is the best pump size for my pool
    A 21,000 gallon pool would work well with a 1HP pump. But you have a spa and a cleaner port to consider. I'd look into a Whisperflo 2-speed pump. If your current pump delivers enough water to the spa to suit you, go with the 1.5HP 2-speed. If you'd prefer to have more water in the spa, then consider the 2HP 2-speed.
    Krickett's Avatar
    Jul 2008
    Arlington, Texas
    82
    What's the purpose/advantage of a 2-speed pump? Also, I've been researching into the performance charts of various pumps and they show feet of water vs GPM and depending on the pump for the same point on the graph it has shown any where from a 1/2 hp to a 1 1/2 hp. Do I need to consider any of these factors and if so how do I best determine those?
    SW Indiana
    9,199
    Quote Originally Posted by Krickett
    It would allow you to run on high for cleaning, spa use or just clearing up a mess, and then to switch it to low for normal circulation to save electricity. It's like having two pumps.
    Analyzing the head and flow curves is important when doing a new install or selecting new equipment, but since you've already got real-world operating experience with the pool, you can rely on that. The complicating factor in your setup is the spa and cleaner. You need a bigger pump for satisfactory spa operation. That means you either have to oversize your pump to manage the spa or go with a flexible pump to meet both requirements.
    Krickett's Avatar
    Jul 2008
    Arlington, Texas
    82
    Thanks for the info. Do you know why different pumps have different hp ratings for the same parameters? How would that choice affect the filter size I need to chose?
    30,419
    Look at pumps that produce enough GPM to turn over all the water in your pool 2-3 times in a 24 hour period.
    The HP issue is quite confusing. What is important is that the pump GPM (that you can get from the manufacturer) should be smaller than the filter GPM (which you can also get from the manufacturer)
    A filter larger than the capacity of your pump will result in a smoother overall system and save you time and money with less backwashes/cleanings. The filter cannot be too big (within reason) but it can certainly be too small.
